Question about Refrigerators
Fridge freezing up at the back and not keeping food chilled
    Scholar:
  • 170 Answers
Either the fan motor is not running, causing frost accumulation on the freezer back - check that the fan is running. Or, you have malfunction in the defrost system - Of of the three defrost components: defrost timer, heater or thermostat
Posted on Jun 29, 2015
6ya staff
SOURCE:
Hotpoint frost free fridge freezer the fridge not working but freezer is
Hi Reginald
Most refrigerator / freezer units chill the fridge area by venting some fraction of the very cold air from the freezer into the fridge compartment through a channel that has a mechanical air valve in it. In this way, it can control the chilled air flow, and aim for the set temperature, all the way down, in some cases, to freezing, or even colder, on the fridge side.
That vent unit, depending on your model, sill be somewhere in the wall that separates the freezer from the fridge. What can happen is that moisture condenses into the louver that slides to control the airflow, it freezes, and then system is stuck, since it's cold on the freezer side, and this keeps the louver frozen stuck. If that is the case, shutting the unit off for a while may recover function, though getting it to where ice is melting in an interior wall may be more risk of food spoilage than you'd want. Otherwise, use a search engine to look for 'how to test freezer / refrigerator vent in make/model', and you'll likely come across all sorts of youtube and step-by-step tutorials.
Good Luck!
D
Nov 30, 2015 | Hotpoint Refrigerators
Fridge keeps FREEZING food in my fresh food pullout drawer!
temperature sensor is not working
this part to control the temperature in the fridge
Nov 28, 2017 | Whirlpool Gold GI0FSAXVY 19.8 cu. ft....
The lower part of my samsung cooltech fridge is freezing all food.
Hi nalin, sounds like you may have a problem with with your defrost timer. Defrost timers can fail due to wear and tear. If this happens during the cooling mode, it will allow excessive frost to accumulate on the cooling coils causing the refridgeration compartment to over shoot its chilling operation in turn causing everything to freeze. Best bet would be to call up a local Appliance Service Technician while the fridge is still manageable so you save on time and money. Also it wouldnt be a bad idea checking the thermostat rotational knob on the rear inner wall of the fridge (if there is one) just to make sure that the machine isnt fully dialed to max chill, hope this helps.
May 01, 2011 | Samsung Refrigerators
Hi i am having samsung fridge cooltsech plus silver nano i have a prob;em in my fridge that in winter the cooling in the refrigerator is very sytrong i have increased the temperatire to 7 degress which is...
If your veg is freezing you need to RAISE the temp in the fridge,if #7 is coldest,then #1 is warmest.SET IT TO #3.You should keep a fridge at +5C for best storage of CHILLED food.you should also adjust your fridge for summer and winter ambient temperatures.a fridge/FREEZER thermometer is ESSENTIAL.OTHERWISE YOUR WASTING MONEY/ENERGY.
Nov 12, 2010 | Samsung CoolTech Plus / Basic Bottom Mount...
Refrigerator is freezing my milk juice and everything. the manual says to lower the number Dont they mean to raise the number.
NO 1 is the warmest with 10(?)the coldest.best get a thermometer for the fridge and try to keep it at +5C,the most economical temp for chilled food.
Sep 16, 2010 | Kenmore Refrigerators
Water dispenser does not dispence water
need to replace the water inlet valve. the part number for this model is 4389178
Jun 18, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Temperature in fridge wont set,for example,trying to set at+4,but keeps reverting back to +12,FOOD NOT CHILLING...Any help appreciated...thanks
freezers have a defrost mode for the coil and it is on a timer, it may be bad. if it is, the coil will freeze with the moisture it pulls from the freezer and not let air pass over it. also, the coil located at the bottom of the unit may simply be dirty.
Nov 26, 2009 | Electrolux ERN2820 Bottom Freezer...
Over Chilling Refridgeration set on 7C still goes to 0C Digital thermostat
sounds like a bad thermostat,you can check it with a meter by putting the meter on omes,thermostat in closed position no reading turn thermostat all the way on you should get a reading if not replace,let me know-mike
Sep 29, 2008 | Westinghouse WRS6R3EW 36" 25.8 Cu. Ft....
Freezing food in upper chill drawer and freezes water in tank
Does you appliance have the custom cool controls ? If it does then there is another air damper in the custom cool unit at the bottom of the fridge compartment
Aug 28, 2008 | GE PSS25NGM Side by Side Refrigerator
Fridge not chilling
check the temperature setting recommended by the mfg. you will find all the info. in the use & care guide.
is it just the fridge or is the freezer acting up as well?
Apr 05, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
