Question about Dell Computers & Internet
My dell stops suddenly and restarts it self after giving me a blue screen so i tried to use diagnosing tool and i got Error Code 2000-0142
My dell refuse to restart else i have to power turning it of after that turning it on then it works normally
Posted by Ahmed Hesham on
De ice
    Diehard:
    Visited the website for 60 consecutive days.
  • Dell Master
  • 711 Answers
Blue screen occuring and the laptop restarts
maybe the problem of your laptop was the memory ram that was built in... or the hard drive i think...
Aug 11, 2012 | Dell Computers & Internet
My dell laptop suddenly started getting a blue screen error and crashing, the error is driver rlqc not less or equal, the laptop is still under dell warrantee is it covered by the warrantee if not how do i...
The Blue Screen Error IRQ Driver not less or equal is a memory problem. Basic things you can do is reseat the memory. However, I highly suggest to contact Dell and have them guide you in doing a Memory Diagnostics. They should replace it if its faulty.
Mar 30, 2011 | Dell Inspiron 1525 Notebook
Dell Hard Drive problem - Computer won't start!
It sounds like you drive has bad sectors. You can replace it with any 40-250GB ATA 2.5 inch drive. If you want your data back, you can still ready you data with tools like ddrescue and create an image file. Then you read the image file with a file carving utility like photorec. It's not quite that easy, since those are command line tool, but your geeky friend will help you with this. If you want somebody else to do it for you there is Data Recovery NYC. Also there is good information on hddguru.com.
May 17, 2010 | Dell (0K724) for Inspiron 8100 40 GB Hard...
Blue screen comes up
To fix the blue screen error try these steps:
1. turn off the computer unplug all the device plugged with the computer except keyboard and mouse.
2.restart the computer and start pressing the F8 the moment you turn on the computer you will get windows advanced boot options select last known good configuration and press the enter key twice. if it works fine if not then
3.restart the computer and start pressing the F8 the moment you turn on the computer you will get windows advanced boot options select safe mode and press the enter key twice after that let the computer boot up when its up go click on start go to all programs and then go to accessories then go to system tools and then select system restore.
you will get a window select the day when your computer was working properly. follow the screen prompts this should help you.
If not please reply back for future help.
Mar 13, 2010 | Dell Latitude D600 Notebook
Blue Screen error, Windows not loading, How can i reset Password?
Vist this page.
you can diagnose the error with STOP: 0x0000000A error.
Go to http://www.make-pc-faster.com/ and visit Blue Screen column.
Feb 28, 2010 | Dell LATITUDE D400 D500 D505 D600 D800...
Dell inspiron 1429 would not stop restarting
just read the error on that blue screen...Its a dump error....then tell me....
[email protected] or on 9665071117
Aug 27, 2009 | Dell Inspiron 1420 Notebook
The computer starts then shuts down.
Try booting up the computer pressing whatever key the Dell needs to boot into BIOS (F10, Delete key, F1...pay attention to the screen) and leave the computer on for about 15min. See if it cuts off then. If it does its more than likely your power supply. If it doesn't then its not hardware related.
Mar 12, 2009 | Computers & Internet
Blue error screen and system shutdown on Dell Dimension C521
Rule of thumb test ram out first usally that is the cause what does the code say on the blue screen
Feb 13, 2009 | Dell Dimension C521 PC Desktop
Blue Screen Error Message
Looks like you've been getting two different Stop errors...
The 1st error, 0X00000024, aka Stop 0x24, is a Windows 2000 error. (XP is just an updated version of 2000) Microsoft gives an explanation here.
For the 2nd error, starting with 0x000000ED, Microsoft's solution is here, with additional help here.
Jan 02, 2009 | Dell Dimension 3000 PC Desktop
My Dell Dimension 4400 running windows XP Home Edition stopped working and displays a blue screen with the following message: STOP: c000021a {Fatal System Error} The windows Login Process system process...
If that is not it reistall and to not loose you files click you partion durring the install and do not format it and click enter then click on leave partion alone
Dec 07, 2008 | Computers & Internet
Computers & Internet Logo
94 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
