Question about Sony VPL ES7 SVGA 800 x 600 LCD projector - 2000 ANSI lumens
Hello.. My projector came on minutes ago now the light is just blinking. Can you please help? I have a Sony vpl-es7
James Smith
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 67 Answers
You might check the following:
* signal is going to the input. If not, does the menu come up?
* air flow is ok. Projectors don't run well if they are hot and can't breathe
Posted on Jul 03, 2015
5 Related Answers
Anonymous
SOURCE: Sony VPL CS5 Multimedia Projector Problem
The Temp/fan light is on and is shutting down the projector what do I do
Posted on May 07, 2008
ABRsvcs
  • 4234 Answers
SOURCE: Reset Timer Lamp Sony VPL-HS60 projector
According to the manual, you need access to the RESET button, the left and right arrows and the ENTER button to clear the counter. Press the following in order for less than 5 seconds each:
RESET
Left Arror
Right Arrow
ENTER
The above sequence should clear the counter.
Dan
Posted on Apr 09, 2009
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: how to reset lamp on sony lcd projector xga vpl-px20
After replacing lamp, connect projector AC power cord and turn the projector in standby mode.
Press following keys on control panel for less then 5 seconds each..
RESET, <==, ==>, ENTER.
That will reset lamp timer in projector.
Thanks.
Posted on Jun 01, 2009
projdoc
jasbo
  • 2239 Answers
SOURCE: Sony Projector VPL-VW 10HT 2 problems 1)The
there is a lock on the projector that needs to be removed. check the manual for the code.
Posted on Aug 20, 2009
projdoc
jasbo
  • 2239 Answers
SOURCE: my projector sony vpl cs6 projects yellow
reset the settings to factory default and change your cable. if that doesn't help, the polarizer filter on the blue lcd panel is fried due to excessive dust and heat. the optical engine will need to be replaced.
Posted on Dec 08, 2009
Testimonial: "Thanks very much for the help. "
Sony VPL-ES7 projector boots up after few seconds switches off, with a red light flashing severally on the power button. Please what could be the problem because i have serviced the projector!!!!
Check the fan connections, one might not be connected right if you have just serviced it. Switching off with a flashing red light usually indicates a fan error.
Also is there a sequence to the flashes? e.g, 4 flashes and pause?
some manufacturers have a fault code table for the amount of flashes.
Nov 09, 2016 | Sony VPL-ES7 LCD Projector
I forgot my password for my Sony VPL-ES7 projector. please help me?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Mar 02, 2016 | Sony Office Equipment & Supplies
Why the remote for Sony VPL-ES7 projector won't change the slides but it will turn the projector off and on?
Have you connected the USB cable to your laptop so that the Sony remote can act as a mouse? Did the laptop respond by loading drivers?
Sep 04, 2014 | Sony VPL-ES7 LCD Projector
Fan goes off at once when i start it
Do you get video signal before it goes off? Look at the lamp/cover led and see if it blinks.
Mar 31, 2014 | Sony VPL-ES7 LCD Projector
Suddenly power off
check the lamp please,
to replace it with a new lamp,to check it
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Mar 13, 2014 | Sony VPL-ES7 LCD Projector
Sony vpl es7
Check the lamp first
We supply original projector lamp,bulb,parts,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Mar 10, 2014 | Sony VPL-ES3 Multimedia Projector
My Sony VPL-ES7 LCD remote control is missing but the control panel is locked. what should i do
you can unlock it only by using remote control
remote control ,unit price is USD20
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, motherboard,
powersupply ... with high quality and competitive price.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: [email protected]
Skype: lampdeng.com
YM: [email protected]
http://facebook.com/lampdeng
http://www.lampdeng.com
Feb 18, 2014 | Sony VPL-ES7 LCD Projector
Projector starts the goes off by itself.
Check the fan is working could be shutting down cause overheat
Oct 16, 2012 | Sony VPL-ES7 LCD Projector
After about two minutes, the projector automatically shuts off.
check that all vents are clear and that the fans are working, it maybe a self protect feature when it detects over heating and automatically shuts off
Mar 23, 2011 | Sony VPL-ES7 LCD Projector
Sony VPL ES7 SVGA 800 x 600 LCD projector - 2000 ANSI lumens Logo
154 people viewed this question
Top Sony Office Equipment & Supplies Experts
jasbo
jasbo
Eric Rotmil
Eric Rotmil
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
