Question about Pioneer Car Audio & Video
I hooked up my pioneer dehx8600bh car stereo everything works perfectly except when I turn my head lights on the stereo loses power and factory reset every thing
Posted by chris silver on
  • chris silver Jun 29, 2015
    When I turn lights off radio comes on
Rob
    New Friend:
  • 64 Answers
Not sure what kind of car you have but,,, just for the heck of it, when you turn on your lights , try turning your interior dimmer all the way up. If the radio works again, then you have it powered from the wrong wire in the dash. It needs to go to a constant hot (12V) and Accy/ignition (12V) and not to a lighting wire which would power the back lighting of a factory radio.
Posted on Jun 29, 2015
5 Related Answers
Anonymous
  • 91 Answers
SOURCE: Car CD stereo
Either you blew the memory fuse or didn't connect the radio to the proper wire. Check fuses inside and under the hood.
The memory wire to the radio needs 12v all the time. If it's not connected or no power at the lead the radio will reset every time you turn off the car.
Posted on Jul 08, 2008
Anonymous
SOURCE: need to hook up a 200 pioneer stereo with wire harness from 96 honda accord to the wiring on a 64 impala
there is only one power wire i cant remember the color use a test light to figure it out...then you need to make a wire off the fuse box that turns on when the ignition is on
Posted on Jul 29, 2008
Anonymous
  • 132 Answers
SOURCE: what is the light blue wire exiting cdx-l550x car stereo
THE BLUE WIRE IS USUALLY POWER ON SIGNAL TO AMP FROM DECK HOPE THIS IS HELPFUL GLENN
Posted on Nov 15, 2008
etirbynnor
Ronny Brite
  • 655 Answers
SOURCE: I AM TRYING TO HOOK UP A CAR PIONEER CAR STEREO
Hello vickie_morto,
You can download a PDF copy of the manual here. The wiring diagram with color code is on page 51.
Hope this helps.
Posted on Jun 28, 2009
Anonymous
  • 3 Answers
SOURCE: I installed a pioneer Deh p49001b car stereo in a
to solve the problem with it turning off when u turn your lights on is that on the back side of your radio is a spot that says max and something else keep your ground wires conected just how they are but get u a a 14 to 12 gage wire a cut u about 6 inches and use one end and connect to your other ground wires (with Connecters ) and the other end and with a closed end connecter with the little hole in the center i cant place wat its called but any ways put it where that max hole thing is where there is a screw there and that should fix that problem cause i had that happen before .. but make sure your antentia is pluged iin to ok .. good luck Paul,
Posted on Aug 12, 2009
I have a 2007 dodge ram 1500 3.7 v6, I'm having trouble with my pioneer stereo! I have everything perfect but when my stereo goes off it resets! What color is the memory wire?
It is usually called the remote wire. Either solid light blue or light blue with a white stripe. On the back of the pioneer deck look for the wire labeled REM+ it's just a 12v constant.
Nov 17, 2013 | Cars & Trucks
Pioneer DEH-3300 UB
Apparently, you have no power at the 12 volt battery/memory wire at the radio harness of the vehicle. This wire is white with blue in color.
Also, based upon your description, you have connected the battery/memory wire and the accessory wire of the radio to the 12 volt accessory (switched) wire of the vehicle. This wire is white with red in color.
Check the radio/ stereo fuse of the car. You may have blown the fuse during your installation.
You have no memory at the radio because when you turn off the key, you lose all power to the radio.
Also, I mentioned the wire colors just in case you used an aftermarket radio wiring harness. Make sure that the yellow from the Pioneer unit is going to the battery power source and, the red of the Pioneer is going to the switched power source.
Sep 12, 2012 | Pioneer Car Audio & Video
Can I hook two 12in. Subs up with a 1100w amp. Sony explode, pioneer subs
Yes....hook one up to the left channel and one up to the right.....once everything is wired up.....keep gain down on amp and turn stereo on.....turn up stereo with amp gain down to right before high end speakers start to distort......then while its playing, turn amp gain up about 1/2 way. close your trunk and hop in drivers seat....sound gd????? You might have to adjust level on amp and bass on head unit to taste.....Be careful though....pioneer subs are only rated around 300 watts continuous.....dont want to blow them...gd luck....
Mar 20, 2012 | Pioneer Car Audio & Video
The speaker output doesn't work
Hi Marlena,
I had the same problem with the 2200ub, so I will post the solution for that. Hopefully its the same for you, if not sorry I couldn't help better.
I have a 2002 Suburban and was installing the Pioneer DEH-2200UB. The suburban had the factory stereo still and has onStar. So I had everything hooked up, purchased the harness which was perfect except for the blue and white wire on the stereo and a solid blue wire on the factory stereo end. I was confused by there being 2 plugs from the factory stereo and one for the 2200.
I finally went to Best Buy and talked to their tech and he told me that since I have onStar I need to cut the pink wire and wire it to the blue and white wire that goes into the new stereo. These guys were great they didn't hesitate to tell me how to do it and even gave me the extra wire and connectors I would need to do it. Best Buy is expensive but I will keep shopping there just because of their service from these kinds of people.
The pink wire is hooked into the amp which I believe is located under the drivers seat. As soon as I did this everything worked perfectly.
I am not sure if the onStar still works, but I don't plan on using it anyway so if that is important to you, you should probably have a pro do the install. Best Buy will install it for $50 (plus parts) but it could be more for dealing with things like this I really have no idea.
Hope this works for you.
Jan 27, 2011 | Pioneer DEH-P4000UB CD Player
Klipsch subwoofer doesn't work with Pioneer receiver
Make sure the subwoofer is hooked up correctly and powered. Also, be sure to make sure the subwoofer is turned on in the Head Unit's settings which can usually be accessed via a button on the face of the Head Unit.
Best Regards,
James
Jul 21, 2009 | Electronics - Others
Illumination?
you need to splice the + wire into the Acc wire. the with power only when you turn the key. and the - wire into the black ground wire. hope this helps
Jan 29, 2009 | iLO XM-MP3-CD Car Stereo
Radio Blowing Tail Light Fuse
by the way you tell me that the radio illumination is the gray wire and all of the rest you are wrong. try the correct way red is key positive,yellow is constant power,black is ground,orange is illumination,blue is remote,gray is right front positive and gray black is negative,white is left front positive and white black is negative,green is left rear positive and green black is negative,violet is Right rear positive and violet black is negative,
Nov 23, 2008 | 1993 Oldsmobile Cutlass Ciera
My pioner stereo is wired up and the only way i can get it to play is to turn my head lights on. is there another way to hook it up.im loosing all of my settings when i turn off the lights. all the wi
first take a test light hook it up to ground metal of carfind witch wire got power when you put the light on disconnect the wire and find a wire that gonna work when you put the ignition on maybe in the fuse box be carefull not to hook it up to direct battery it gonna work but if you forget the radio on it gonna drain our battery cheers
Jan 13, 2008 | Pioneer DEH-P6600 CD Player
Sound shuts off, sub still works
That is a common problem with this radio, for it can not go to loud without going down in volume or shutting down.
Dec 08, 2007 | Pioneer DEH-P3100 CD Player
Overall Problem - Panasonic RX-ED707 won't work properly at all
only 1 reason for that faults :
there is a flat connects the top panel which has all the controls with the other circutes in the stereo...
so you have to open it and care for the cd unit it damage easily then check the flat for loseness or cuts
it happened to me also and that works perfectly
good luck
Nov 14, 2007 | Panasonic RX-ED707 Boombox
Car Audio & Video Logo
87 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
