Question about ConairPro Canine FX - Turbo-Groom II Professional Animal Clipper
How do I put blade back on - ConairPro Canine FX - Turbo-Groom II Professional Animal Clipper
Posted by Linda osawa on
What is the procedure in putting a blade in the scroll saw?
there are 2 methods of blade retention
1-- is a small screw in the side of the retainer that jams the blade in place
2--- the blade is held in place by a collet actio pull the blade shaft all the way back into the machine -- pull the retainer at the ed of the shaft back further up against the machine and the old blade will fall out -- put in the new blade and release the collet retainer
Jan 18, 2016 • Saws
HOW DO I PUT MY WAHL HAIR TRIMMER BLADES BACK TOGETHER
well the smaller blade sits on plastic piece that is coming out of the clipper, having the inside of blade towards you. then larger blade ,the inside of that faces smaller blade,and align them to where you can see smaller teeth thru larger ones put screw back in and tighten. then oil them.
1helpful
Model RZT42. When you back up the blades shut and when I go back to forward, the blades will not engage.
Some of the newer riding mowers have a safety system on them that won't let the blades work while you are backing up. If the blades are engaged and you put it in reverse they will stop. You usually have to reset the blades, turn them off then back on, when you put it back in forward.
I have a used Cub Cadet Model #144-664-100 that I purchased last year and used half of the summer and ran great but towards the end it wasn't cutting very cleanly. So I took off a mower blade, which was...
Have you tried running it with the blade back on? It may be ok as there is a braking system built into the pto clutch that makes the blades hard to turn by hand. Regards Phil
2helpful
Oster clippers blade
John! No Problem!
First put the bigger of the two blades witht the size/number facing down, put the cutter on top. (with the side with the flat side of the teeth facing down) Then put the tongue guide inside the tension spring, make sure the tension spring rail is on the tension rail and place them on top of the cutter. To see which bits these are go to: http://www.sheareaseltd.com/clipper-blade-sharpening/clipper-blades-the-parts
This picture whows the front and back, it differs slightly from your blade, but its same meat different gravy!
Hold all this together with your finger and thumb, flip it over and scre the whole lot together!
How to put differnt blade on oster a-5 clipper
There is a small gun-metal colored bar at the very rear, just below the back of the blade. It pushes inward, in the direction of the blade. Push it firmly in and pull up on the teeth of the blade. It should pop upward. You can then remove the blade from the tongue that it sits upon. When you want to put it back, slide the blade back on the tongue, then, WITH THE MOTOR TURNED ON, push the blade down to its seated position. It will click into place.
3helpful
The whole blade set has come off and we have no manual to put back together
There is a small gun-metal colored bar at the very rear, just below the back of the blade when it is only the clipper. It pushes inward, in the direction of the blade. Push it firmly in and pull up on the teeth of the blade. It should pop upward. You can then remove the blade from the tongue that it sits upon. When you want to put it back, slide the blade back on the tongue, then, WITH THE MOTOR TURNED ON, push the blade down to its seated position. It will click into place.
If you have taken the blade off and the tongue has for some reason flipped back against the head, slide a screwdriver blade behind it and flip it back out so you can slide the blade back on it.
Good luck
59helpful
4answers
I took my Wahl clippers apart to clean ......
Okay I fixed mine. this is I what I did and it works now take the big blade and put it on a table, take the little blade and put on top of the big blade if you look closely at the big blade you can see where the little blade went, make sure you allign the blades. next take the white thing dont know what you call it bit it rotates the blades put that on the little blade, take the gold piece align with holes to the big blade and take the silver piece allign with holes and then put the screws back in. when you put it on the clipper make sure the white piece goes in the hole that rotates the blades and sould go in fine
Jun 08, 2009 • Wahl 8550
3helpful
2answers
Reassembling blades on hedge trimmer
the blades are stuck , i spray my trimmer with wd40 before every use to keep them juicy you should too. also sometimes if you hit a large stick it will put a divot in the blade cause ing it to stick. as for putting it together, find some one who can do it without directions. but when you use them next make sure you soak em good with wd40 or something if you dont i guarantee they will always stick. wd40 willl not hurt any shrubbery, as ive been doing it for years.
Put on mower blade for black and decker lawwn mower
Hi, unplug the spark plug wire.turn the mower on its side, in the middle of the blade there is a bolt. Unscrew the bolt on blade to take it off, and to put it back on, put blade on first and bolt it back together.
If this doesn’t work for you, please write back.
Thanks
ConairPro Canine FX - Turbo-Groom II Professional Animal Clipper Logo
Top Conair Pets - Others Experts
Tom Chichester
Ruth summersides
Kardoc
Are you a Conair Pets - Other Expert? Answer questions, earn points and help others
