Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
Tv will turn off after about 1hr then i can turn it back on but it might stay on 1 half hr then it goes off again and i have to turn it on again what is the problem
Posted by danny melear on
42pfl5432d37
Kindly do not attempt to switch on the TV like this. You might damage more components/parts/boards. Look for any loose contacts in power outlet, RC jack, cable and socket. I think the TV needs servicing.
Aug 21, 2012 | Televison & Video
Need to reset washer it is stuck in mid cycle and wont continue nor start over
doesnt this model have the cancel button by the start button.......if so........switch on then hold cancel for 10 seconds...........
cheers
Jul 24, 2017 | GE WBVH6240F Front Load Washer
Shuts off after about 1 hr and then we have to power off
The TV might be on sleep mode, so it will stay on for an hour, then turn off again. You'll need to turn it off through the menu
Apr 03, 2009 | Hitachi 60SDX88B 60" Rear Projection...
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
DLP tv
need the model number of your set in order to help, but it sounds like a problem with the light engines shutter
May 14, 2008 | Televison & Video
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
TV Shuts Down
you may have vertical intermitance resold vertical ic or check connector to deflection yoke some time is intermiten..
Mar 23, 2008 | Mitsubishi VS-55707 TV
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
Demonic-2011
Demonic-2011
