Question about Frigidaire Heating & Cooling
Frigidaire AC model LRA187MT2. Compressor runs nonstop - does not matter what the temperature setting is. When put into fan mode displays H1 instead of the temperature. Filter is clean.
Posted by Gerry Flynn on
jack morton
    Master:
  • 523 Answers
You probably have a circuit board failure. On the board there are micro-relays that control power to the compressor. And in that relay the switch that is normally open is stuck closed.
Posted on Jun 29, 2015
2answers
My unit blows out cool air for maybe 3mins. Then warm air
Normal ACs (non inverter) work in the following way
  • The AC compressor runs continuously till set temperature is reached in the room
  • The compressor then switches off, but the blower fan in the wall mounter unit keeps running. Durint this time the AC fan blows air out at Room temperature (which feels warmer)
  • When temperature of room rises then compressor starts running again. During theis period the air coming out from the inner uny is cooled by the condenser coils
  • And the process is repeated.... as long as you keep AC running
Ac works this way throught the operation period.
Now if you feel that your AC keeps switching off and on very frequently check the following
  • Your AC may be over powered for room *for example a 1.5 ton AC installed in a scenario where 1 ton is enough)
  • If there is voltage fluctuation in your area then the compressor may keep shutting don on large voltage swings
    • Solution: Get a Stabilizer
  • You have set the temperature setting too high. Max temp suggested for ACs is 25 degree Celsius, any higher will mean the compressor shuts down often. Remember every compressor shutdown and startup draws a high starting current
    • Set AC temperatures between 22 and 24 degrees Celsius
  • The thermostat/ Temperature sensor is faulty
    • Get unit inspected by Authorized technician
  • There is dust buildup on the outer unit / compressor unit. The dust buildup may cause overheating by preventing efficient heat exchange, This may lead to overheating of compressor and it shuts down to, prevent damage to itself
    • Get unit serviced by Authorized technician
  • The fan motor of the outer unit is not working properly
Remember to get the AC serviced at least thrice a year to ensure smooth operation
Cool Thoughts... Cool Life !!!
2answers
I have a RUUD Model number UGDU-15EARJR and the blower fan is not coming when in a call for A/C
If you turn your T.Stat to run and it comes on but in the auto mode it does not come on and the condensed compressor and ODF COMES ON sounds like you need a circuit board
How Do I Know that the Huawei S5700 series switch's Fan Operates Normally in Intelligent Mode?
The fans can work in the intelligent mode or forcible mode.
In the intelligent mode, the fans start to operate only when the ambient temperature goes higher than a specified value. In V200R003C00 and later versions, you can run the display fan speed-adjust threshold minus command on the switches that use the intelligent heat dissipation mode to view the temperature thresholds for the fans to start and stop running. The set fan speed-adjust threshold minus command can be used to lower these temperature thresholds.
Intelligent heat dissipation:
Huawei S5700-24TP-SI-AC
Huawei S5700-24TP-SI-DC
Huawei S5700-48TP-SI-AC
Huawei S5700-48TP-SI-DC
Frigidaire side by side refrigerator/freezer has h1 flashing on refrig. side
H1 is temperature detected as too warm. Is compressor running? Are evaporator and condenser fans running? Is there frost build up on inside back wall of freezer?
Code H1 on my frigidaire ffhs2622mwla refrigerator
HI is an error for freezer temperature detected as too warm... Look for frost on the back wall of freezer (defrost failure), or a failed evaporator fan (you should hear it running in the freezer compartment), if the food in the freezer is beginning to thaw, check the compressor to see if it is running. If the compressor is running, but the freezer isn't cold enough, and the evap fan is good with no frost build-up, you may have a sealed system leak (refrigerant charge is low). Frigidaires really suck in recent years and have lots of leak issues...
Side by side fridgidare wont stop beeping and showing H1, freezer door was cracked all night and our ac was out, tried to unplug and reset still nothing???
Hey Nikkie, I appreciate your post!
I see that your Frigidaire refrigerator is beeping and displaying the error code of "H1". An "H1" error code means that this is a high temperature within the refrigerator. Since the door was left open all night the refrigerator is registering there is a high temperature. I would suggest keeping the door closed and allowing the refrigerator to get back to the correct temperature. This may take anywhere from 24 to 36 hours for the temperature to stabilize. Hopefully this information is helpful to you. -Matt
How do you turn off power saver on frigidaire air conditioner
Good Afternoon Friend,
I understand you want to know how to turn off the power save mode for your Frigidaire air conditioner, model# FFRE12L3Q1. Your appliance will run in energy saver(econ) mode when used for the first time. In this mode, the fan will continue to run for 1 minute after the compressor shuts off. The fan then cycles on for 20 seconds at 10 minute intervals until the room temperature is above the set temperature, at which time the compressor turns back on. You will be able to turn the energy save mode off by selecting your temperature as well as your fan speed. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
1helpful
Ac fan not running, but compressor runs on and off
switch/ fuse possible if it has one, if not one of the wire going to the motor was severed, or the start up capacitor of the motor if it also has one.
5helpful
2answers
Fridgeaire error code H1
Hello - Could it possibly be HI? Typically error code HI indicates that the unit has detected high temperature in freezer. Try setting the unit to a lower setting. Generally the factory setting is 0 for the freezer temperature and 37 for the fresh food temperature.
2answers
What do the controls on a portabel AC mean. Like the mode button.
my 4m40mitsubishi model have something nocking during a litlle accelerating in the acelerator
Heating & Cooling Logo
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Steve Oakes
Steve Oakes
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
