Question about RTO Ho Herpa Freightliner Truck Tractor
Caterpillar 3176 7LG in a 92' Freightliner. This motor is known for breaking the a/c bracket. Anyone know a general cause other than misalignment? And how to properly align motor bracket compressorTY
Posted by jack morton on
What would cause a code 4354 on a 2016 Freightliner Cascadia?
the code means something but only if the engine make , type and transmission make and type is known
Freightliners run 3 different engine and up to 4 different transmissions and the code will be specific to that combination
take it to a freightliner service center and have it fixed
Oct 01, 2016 | Cars & Trucks
Clucking noise coming from rear of truck when loaded on my freightliner semi truck
I don't know that much about trucks, but I would see if all the brakes are releasing, you may have a set or two sticking.
Sep 19, 2014 | RTO Ho Herpa Freightliner Truck Tractor
General Electric Washer Model# whre5550h1ww makes a clacking sound in wash cycle about i se
There is a known problem with this GE model. Remove the front panel, look at the base plate below the motor. Can you see that it has been rubbing there? On that model the "front apron bracket" fails allowing the motor to rub againist the base. You will need to replace the apron with the new design they have out.Here is the part to order.
You may also check this by removing the front and run a load of wash and watch the motor.
Please post back your finding to me.
Nov 02, 2012 | General Electric WHRE5550H Top Load Washer
I need the exact location of the break light switch on a 92 labaron 2.5
The brake light switch is mounted to the brake pedal bracket assembly, under the instrument panel. The stop lamp switch attached to the mounting bracket.
  1. Disconnect the negative battery cable.
  2. Unplug the two brake switch wiring harness connectors.
  3. Remove the wiring harness for the switch from the clip on the brake pedal bracket assembly. Remove the nut and washer from the switch and bracket assembly stud and remove the switch and bracket assembly. To install:
  1. Position the switch and bracket assembly to the brake pedal bracket assembly, then install the nut and lockwasher. Tighten the retaining nut for the bracket until finger-tight (loose enough to allow movement of the bracket).
  2. Attach the electrical wiring harness connectors and route the wire through the retainer clip.
  3. Push the switch forward (toward the front of the vehicle) as far as it will go (this will cause the brake pedal to move forward slightly).
  4. Gently pull backward (toward the rear of the vehicle) on the brake pedal until the pedal lever rests against the its stop. This will ratchet the switch back to its properly adjusted position.
  5. Tighten the switch and bracket assembly mounting bracket nut securely.
See fig for more detail:-- helpmech_9.gif
-------------- This should help.Thanks.Helpmech.
Jan 12, 2011 | 1992 Chrysler Lebaron
How expensive is a busted intake, vehicle is running hot
The intake manifold on those motors are known for cracking near the passengers front corner causing a coolant leak. Replacement can run up to $1k.
Nov 11, 2009 | 1998 Mercury Grand Marquis
RTO Ho Herpa Freightliner Truck Tractor Logo
90 people viewed this question
Top RTO Toys Experts
Marvin
Marvin
ray gallant
Bill Boyd
Are you a RTO Toy Expert? Answer questions, earn points and help others
