Question about Microsoft Zune JS8-00001 Digital Media Player
What size screws fit at the rear of a senzu ld3700 TVs for a wall bracket?
Posted by Derek fernandez on
What size screws do I need to mount my Polaroid model no. Tlac 02255 to a wall bracket?
Dear Billy,
It is very difficult to determine what size screw for the TV bracket.
  • If you bought a wall bracket, it will definitely have different sizes of screws in it.
  • Follow the installation guide for what Size screw to use on the TV. It varies by manufacturers.
  • Get a Universal Bracket.
Good Luck!
JP
Jul 08, 2015 | Polaroid Televison & Video
Can my tv be wall mounted and is there a special kind of wall mount
Check Walmart , all types / sizes of Wall mounts available
Mar 16, 2015 | Televison & Video
Hi I have a digimate tv model modl lt321c2m1 and I am wondering if I can mount it on the wall. Can I?
Please look on the back, there should be 4 mounting holes (for Metric screws) Iin what is called VESA mounting pattern. Just measure the pattern.
http://en.wikipedia.org/wiki/Flat_Display_Mounting_Interface
When you buy the mounting bracket, it will come with a bag of Metric mounting screws to attach your TV to the bracket.
Jun 13, 2011 | Digimate DGL32 32 in. LCD Television
Hi,WHAT SCREWS DO I NEED TO PUT IN THE BACK OF MY TV SET WHEN PUTTING ON THE WALL AS THE ONES I GOT WITH THE BRACKET DONT FIT,THANX
If the set size match the size of the bracket it should have fit, I would look on back for a screw that is already in set and see if it fit the holes you need, if so then you can use them if you have atleast four, if not then take that screw to a local store and match it up.
Jan 20, 2011 | Samsung LE32A41B 32 in. HD-Ready LCD...
Can't find screw size to fit back of my 42in Toshiba Regza. I want to mount on wall. Screws that came with the 42in wall mount don't fit it. It's not a 5/16, 6mm, 8mm fine thread or course thread
M8 - according to a document I found online for a Toshiba mounting bracket kit for their LCD TVs the bolt size is M8. It should be easily available in a large hardware store or place that sells large flat screens.
Make sure you hand tighten it into the mounting hole before attaching any brackets, to judge the proper depth for tightening. Over-tightening with a long bolt could damage the TV.
Dec 19, 2010 | Toshiba REGZA 46RV530U LCD TV
LG 42" wall mount screw size
Metric M5 or M6, when you buy wall mounting bracket, it will came with a bag of screws for attaching the TV to the bracket. All my wall mounting brackets for my TV come with screw.
http://s807.photobucket.com/home/budm/allalbums
Jul 01, 2010 | Insignia LCDTV26 26 in. Television
I have a Samsung LE26. I bought a wall bracket for tvs with vesa fittings. Although the holes on the backplate are in the correct place, they holes in the back of the TV are a different diameter to any...
There is no such bolt size as 4.5mm, if you look in to an imperial size bolt instead you will find that the imperial size converts back to 4mm or 5mm (M4 or M5 and nothing in the middle).
Samsung can not advise on the correct bolt for your tv model as they do not have the specification for this, this is a factory error - no other Samsung model hase this problem.
You can use PTFE tape, wrap this around the M4 bolt to give it .5mm, PTFE tape is used by plumbers to make screw threads water tight when using compression fittings.You can buy PTFE tape from any DIY store.
I have a samsung LE model, 32", I bought a TV wall bracket from an excellent website called http://www.mountright.com , they supplied with a UMount TV bracket which came with all the correct bolts for my Samsung TV.
Sep 13, 2009 | Televison & Video
What is the screw hole size in back of tv
The screw holes are metric. The set is supplied with M5x25 screws to attach the pedestal, so the wall mount screws will be in that same range.
Mar 01, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
42'' LCD PLTV-4250 MOUNTING
The universal mounts generally have a selection of screws that are to fit different makes and models of tvs.
If you bought the appropriate size mount for the size of your TV, there should be mounting holes that match your TV, and screws that will secure it.
I have not seen any mounts that use more than four.
Apr 07, 2008 | Protron PLTV-4250 42 in. LCD Television
Microsoft Zune JS8-00001 Digital Media Player Logo
96 people viewed this question
Top Microsoft Audio Players & Recorders Experts
john h
Marvin
Marvin
ray gallant
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
