Does it have disc or drum brakes? If it has disc see if the rotor has turned blue from heat most likely stuck caliper. If it has drum brakes remove drum look for pieces springs adjuster e.t.c. if everything intact turn axle see if you hear noise usually a bad or locked up hub bearing will make loud humming noise.
