Question about Freezers
Service manual for Norlake F23S Freezer will not start up
Posted by Scott Oestreich on
2 Related Answers
22yooper
James Helmer
  • 828 Answers
SOURCE: walk-in norlake freezer
Check the evaporator coil for frost buildup on the back. Check for frost on the suction line, the biggest line returning to the compressor. If frost is evident at these places you have a defrost system problem. These systems have a defrost timer that defrosts the coil at preset times. Check the timer for proper operation by marking the position of the dial and check back to see if it changes. If it does not change position the timer motor is most likely bad. If the dial is not rotating automatically you can manually turn the dial in the direction of the arrow and put it through a defrost cycle.
Posted on Sep 14, 2008
Dennis Boxerman
  • 1303 Answers
SOURCE: norlake freezer 6x6 not freezing enough
Normally freezers are kept at zero. Most health departments will not allow the temp to be higher than plus 10. If you want to store ice cream, you need to be at minus 10 degrees to minus 15 degrees.
let me know if I can be of any further help.
Posted on Jul 19, 2010
Freezer won't shut off
Hi John,
The symptoms do indicate a failed thermostat.
I am not sure where you could get a thermostat for this freezer but I would try contacting Norlake first. They may guide you to who has one or maybe they can sell you one. If it is a direct replacement it is something that you can do yourself.
http://www.norlake.com/
May 09, 2010 | Nor-Lake Freezer Norlake Refrigeration 6'...
Norlake freezer 6x6 not freezing enough
Sep 29, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
I have a 6x6 norlake walk in freezer. The door remained open for 6-7 hours by mistake and now temperature does not go below 15 degrees. The technician told me to replace compressor as slowly temperature...
I've worked on freezers for over 20 years and have never heard of a compressor going bad because the door was left open. think about a second opinion.
Also, has the cooling coil inside the box developed and frost or ice build up? If so, it needs to be completely defrosted. If you defrost it manually, use a hose hooked up to hot water. Kill all power and hose all build up off. Remove the sheet metal housing ends and be sure there is no ice inside there too. I would go in this direction first.
IN order to kill a compressor under this condition, something really strange must have happened as anything is possible in a refrigeration system. Good luck and hope this helps.
Sep 06, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
Need to know breaker and wire size to run from panel
Compressor 12/3 with 20 amp dual pole breaker. 220 VAC
Freezer 12/3 with 20 amp single pole breaker 120 VAC
May 24, 2009 | Nor-Lake Freezer Walk In Freezer 6ft x...
I would like to know the standard temperature for a freezer
The factory presets your temperatures to the MID / MID setting of 0ºF for the freezer.
Apr 22, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
My freezer stays at 29 and won't freeze
check out the defrost timer it sound like its in defrost. if that is not whats wrong then you can checkout the refrigerant by looking at the sight glass on the liquid line. It dhould not have any boubbles in it and if there is then your low on charge, n if threr isn't then you whille probebly be better off calling a service company out to repair the unit.
Jan 10, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
Walk-in norlake freezer
May 25, 2008 | Nor-Lake Freezer Norlake Refrigeration 6'...
How do turn the temp up on a norlake walkin?
They are usually mounted on the front panel of the evaporator or mounted on the wall behind the evaporator.There is a possibility that the temp. control is at the condenser,and the sensing bulb was slipped thru the wall.Look for the bulb at the back of the evaporator and follow the cap tube.
Dec 05, 2007 | Nor-Lake Freezer Norlake Refrigeration 6'...
Freezers Logo
146 people viewed this question
Top Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
