Question about Alba Televison & Video
My alba tv suddenly went black as i was watching a movie. The sound is fine doe However if i point a flashlight close to the screen i can see a faint image Whats wrong with it?
Posted by Samira Tavares on
De ice
    Diehard:
    Visited the website for 60 consecutive days.
  • Alba Master
  • 711 Answers
Bad inverter, power supply
LCD LED TV Repair No Image Blank Black Screen Flashlight Test How to Fix...
about 4 min in he will explain it
Posted on Jun 24, 2015
5 Related Answers
Anonymous
SOURCE: sound works but no picture. black screen
I've had the same problem. Usually, if I turn the TV off and then back on again, it's fine.
Posted on Mar 05, 2009
Anonymous
  • 1077 Answers
SOURCE: TV screen went negative. Brand new TV
I would use the warranty for this problem. The part that need to be replaced can be somewhat expensive.
With the credit card statement, you can use that as a receipt.
Posted on Apr 11, 2009
Anonymous
  • 458 Answers
SOURCE: lcd LG television...sound suddenly stopped. no
replaced main board
Posted on Aug 18, 2009
Jim Krause
  • 1779 Answers
SOURCE: 47inch toshiba lcd tv (HL167) black picture, but
Best to replace both at the same time . Yes they are easy if you can find the parts.
Posted on Dec 15, 2009
Anonymous
  • 4 Answers
SOURCE: LG 50inch Plasma received loud sound then went black
My friend's LG 50" plasma tv has the same problem and it cannot light up. The picture and sound are working fine. But the brightness is too low. It is purchased 2006 too and out of warranty. So I opeend up and found 9 capacitors 3300uF 10V on the power module at the middle of TV are popped. I am planing to replace all of them. They are available at digikey.com. I think this model's power module has design flaw. The cap rating may to low. 10V? Stay tune to see what happen after I change the all the caps.
Posted on Feb 21, 2010
I have a LG 50LA6200 LED TV, about 3yrs old. While watching it, the screen suddenly went black, the audio is fine.
In the dark with the set on do you see light if you look through the vent holes in the back?
Oct 19, 2017 | LG Televison & Video
I have an Alba LCD 19 inch. Today as i was watching a movie the screen went black but the sound was fine.However if i put a flashlight in the screen i can still see faint image. Can u please help me
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
Jun 24, 2015 | Alba Televison & Video
We will get a black screen but still have sound.
Sounds like a main board that controls everything on the screen and then some.
Since a LCD do the flashlight test (what I call it) : darken the room as much as possible and with a flashlight and the set on look closely at the screen, see a very very faint image of the picture or not?
Dec 22, 2012 | Vizio 42 in. LCD TV
I have an Insignia NS-LCD37 was working perfectly fine, all of a sudden the TV went black, I would turn the TV on and you would get the
Most likely you have a fault in the back light circuit. To verify this, turn on the set, when the screen goes black, take a bright flashlight and shine it on the screen. It may be easier to dim the lights in the room so that you can see the faint image on the screen. If you see the faint image, you indeed have a back light problem. You will need to get a diagnoses performed on the set to track down the problem
Nov 22, 2012 | Insignia NS-LCD37 37 in. LCD TV
Sony bravia black screen audio ok
It is a LCD set and if sound get it in a very dark room and with a flashlight and the set on look to see if you see a very faint image on the screen.
Almost all these sets use a back light system for brightness---an inverter of some type to power the lights---either the back light is bad or the voltage for it is not present or being turned on.
Nov 05, 2012 | Sony BRAVIA KDL-52XBR3 Television
Plasma screen suddenly went out
its a lcd ? replace the lcd lamps or the inverter
May 04, 2012 | Panasonic Televison & Video
I HAVE A SVA 37in HD VR3718W tv, that just went out. we were watching it and all of a sudden it just went black like someone turned it off but you could still hear the sound..what do i need to fix it and...
Without testing the tv all i can say is that, from your description, it can be only the T-con board or the ballast for the backlighting. Take a flashlight and point it at the screen from up close - if you see the image there it's the ballast, if you don't the t-con.
These are the boards
T-con http://buy.id.ebay.com/buying/id/display/110575838928_SVA-VR3718W-LCD-Controller-Board-Part--6870C0060F
Ballast http://goo.gl/SJkA6
Jun 21, 2011 | SVA-USA VR30 30 in. HD-Ready LCD...
Sound but no vision, black screen
It's either the backlight lamp or backlight inverter is busted due to a power failure or fluctuation. Here's how to determine which is which:
  1. Grab a flashlight.
  2. Turn on the TV.
  3. Shine the flashlight onto the screen.
  4. If you cannot see any display even a faint one, the backlight inverter is dead, else the backlight lamps are busted.
  5. Replace which ever is the culprit.
Sep 25, 2009 | Sony Televison & Video
Televison & Video Logo
250 people viewed this question
Top Alba Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you an Alba Televison and Video Expert? Answer questions, earn points and help others
