Question about Maytag Ensignia 3.3 cu. ft. Top Load Washer
I need to find the water strainer on my machine water is flowing slowly
Posted by Alma Harness on
Tim Blodgett
  • 691 Answers
Find out why hobart bar aid hood dishwasher not rinsing
A model number would be handy...
Take it the thing fills OK (possibly a bit slowly?)
Unboosted machine look at water pressure/flow (clogged strainer; shared supply; scaled boiler outlet);
Boosted machine look at booster pump (motor dead; impeller broken; capacitor failed)
Feb 16, 2015 | Hobart Dishwashers
How do i fix FH
FH is Fill Hose error. Turn off water supply and disconnect hoses from back of machine, clean off strainers on back of machine where hoses connect and make sure you have water coming through hose. ( you can turn the water on slowly one hose first then the other and catch the water in a pot or mop bucket. You should have a steady water flow.) hook hoses back up, turn on water and test.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Dec 11, 2013 | Kenmore Elite 45986 Front Load Washer
Our Asko dishwasher slowly fills with water after it has finished washing, this happens over a couple of hours. Asko model 1253.
Check the inlet water flow to the machine. Clean the strainer attached to the junction of the rubber hose and the machine.
The strainer is submerged in the machine body. Pull it by hand and clean. It is small in size.
Sep 22, 2010 | Asko Dishwashers
Looking for tank psi trying to get better water psi out of the shower and taps
Every faucet and shower have a water saving restricter in them. Remove them from the shower head and end of the faucets.
They are about the size of a dime and with about 1/8" hole in them in which water flows out. So the flow is getting restricted from 1/2' flow to this giving you a water saving about a 1.5 gpm.
Below is some more information for the web site please check it out for further help.
http://www.inspectapedia.com/water/Poor-Water-Pressure-Diagnosis.htm
Poor water pressure just at certain plumbing fixtures? poor cold water pressure, hot water pressure, or both hot and cold water pressure or flow that is observed just at some plumbing fixtures in a building while flow and quantity are good at others suggests that the water flow or pressure problems are local to certain runs of supply piping or to the specific fixtures. Check the following first:
  1. Clogged aerator or strainer on sink faucets - clogging by dirt, debris, corrosion, can significantly reduce both hot and cold water flow at a sink where the strainer needs cleaning or replacement. Unscrew the strainer from the faucet and turn on the water - if the fixture pressure or flow is much better you've probably found the problem.
    Look at the aerator/strainer: inspect it, clean it, perhaps soaking it overnight in vinegar to remove corrosion and mineral build-up, or just install a new aerator/strainer.
Jun 04, 2010 | Plumbing
KUDS01FLSS0 Dishwasher - tub slwoly filling with
Slow fill of water is due to the strainer clogging. Strainer is located on the body of the machine where the inlet water hose is connected.
Clean all the water flow tubes in the machine.Clean the solenoid valve opening also.
May 26, 2010 | KitchenAid 24 in. KUDS01FLSS Built-In...
Our Maytag dishwasher has all of the sudden stopped rinsing the dishes. The machine sounds like it is running but no water is flowing. The wash cycle runs but not the rinse. Any clues as to why
Check inlet water supply for free flow. check strainer for blockage. Strainer is located at the machine body water inlet tube entry side.
May 03, 2010 | Dishwashers
Low water flow
Check the cutoff valves under the sink to be sure they are fully open. One could have gotten bumped when putting something away. This is particularly likely if only the hot OR cold is running slowly but not both.
Apr 17, 2010 | Plumbing
Wont pump water
1. Suction strainer with checkvalve must be always
under water.
2. Check the suction checkvalve if holds water. Water
must remain steady when primed.
3. Open the priming port, and fill it full with water.
4. Close the flow control valve.
5. Switch the power on and start the pump.
6. Then, slowly open the flow control valve, to the
level such that it will not break suction, and
stabilized the water flow..
May 04, 2009 | Plumbing
E4 error after attempting to fill and get to temp
This is what I found for the E4 code...hope this helps...and thanks for rating my effort...The Fang.
Machine won't fill or won't fill high enough(LX18, LX30 display shows "E0," "E2," "E3," or "E4")
1.Low water pressure — check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2.Make sure probes are clean.
3.No water pressure — main water supply valves may not be working.
4.Drain valve open - turn machine off to drain machine, then on. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the
OFF-ON procedure.
5. Delime machine.
Apr 28, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart LX15H indicates E4 and will not fill.
This is what I found in the manual...and on a couple of other sites....
OFF-ON procedure.
5. Delime machine.
If this doesn't help let me know and I will get to the bottom of it....good luck and thanks for rating my effort...The Fang.
Apr 27, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Maytag Ensignia 3.3 cu. ft. Top Load Washer Logo
43 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
