Hotpoint Ultima WF860 Front Load Washer Logo
J
John Shae Posted on Jun 24, 2015
Heard a loud pop from machine after starting the program.. machine continued to work but stuck on 1 min to end
1 Related Answer
Anonymous
  • 100 Answers
  • Posted on Jan 27, 2009
SOURCE: hotpoint WD 865- washes ok, dryer won't work makes loud popping
sounds like the dryer heater element has worked loose perhaps and shorted out against the metal dryer box which sits on top of the drum.
best to get an engineer out i'd say.
True GDM-10 started making loud noise AFTER door was slammed after getting something inside; checked inside fan was running slow. Noise sound like something stuck in motor.
without knowing age of unit, I suggest replacing the motor. Sounds like the armature is worn the bearings and is moving inside the windings of the motor. I would do that first before moving forward with any other repairs.
4helpful
2answers
I installed Dell Vostro 1000 System BIOS, v.2.6.1, A04 on myDell Vostro 1000. When it was finished the screen went black and it won't start. Now what? is the computer ruined?
Yep I did the same. Finally recovered using the link shown below.
http://hotfile.com/dl/113520903/05689ed/VOSTRO1000_CRISDISK.ZIP.html
To Create a Crisis Recovery USB you must use a Win XP system
Note: Running XP through compatibility more in Win 7 will not work
1. Insert Blank USB Drive
2. Open "CRISDISK" folder
3. Open "WINCRIS" application
4. It should detect the USB Drive
5. Click "Start" Button
WINCRIS should create the USB recovery drive
6. For Crisis recover, be sure to Power drain system.
A. Remove Battery
B. Depress power button for 10-15 sec.
7. Insert USB drive into USB port.
8. Hold END button while plugging in power cord in system
9. Continue to hold END and depress and release the system power button.
10. Continue holding END until USB drive begins to flash and a beep is heard.
11. System may remain blank as it enters recovery mode - Anoying Beeping will be heard - Beeping will stop and FANS will function Another series of Beeps will be heard
12. System should complete recovery in 5-10 min. If system has not powered down in 15 min, power down by pressing the power button
Good luck Dean/Steve
1helpful
I have a singer curvy 8763. As soon as I started sewing, I heard a loud pop and smoke came out of the machine. Now it does not even turn on. How do I fix this?
I would call Singer at 1-800-4singer and have them direct you to an authorized warranty center. This sounds like an serious electrical problem and should be covered under warranty.
Pop & clutch stuck to floorboard
probly the clutch fork or through bearing
1helpful
Electric Dbl Wall Oven-loud popping noise at end of self clean
Bill ,i dont suspect the control unit is the problem im going back to the loud pop you heard I would say the pop you heard was one of the elemants blowing and that the reason the the breaker tripped if you say the clock,timer and light functon are ok it more so points to an elemant in most cases when an elemant blows it breaks the circuit .but the other componants also work when you reset the breaker i think in this case bill i would call a electrician it needs testing,sorry i could not help this time bill,but do not hesatate to contact me if i can help you again.adrian
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
