Question about Kitchen Ranges
What dose SA6 or SAb stand for?
It comes up on the control panel.
Posted by Chester Sheets on
johnny rebel
    Top Expert:
  • 10,875 Answers
Your range is probably in the Sabbath mode. The error code shown on the display is"Sab", not "5ab".
To disable the Sabbath mode push and hold the Clock pad for 3 seconds.
Posted on Jun 24, 2015
We had some sort of electric power failure last night lasting only a few seconds, but now none of the control buttons on the gas range function. In the time window 5a6 shows. No way to use the oven.
You are in Jewish Sabbath Mode, it is 'Sab'
Search Results Your range is probably in the Sabbath mode. The error code shown on the display is"Sab", not "5ab". To disable the Sabbath mode push and hold the Clock pad for 3 seconds.Nov 10, 2007
Maytag Oven WEIRD Error Code 5ab - Appliance Repair Forum
forum.appliancepartspros.com/oven.../2348-maytag-oven-weird-error-code-5ab.html Feedback
About this result
Will you tell me what error code 5A6 means on Maytag MGR6875ADQ ...
https://www.shopyourway.com/questions/1098960 Nov 24, 2010 - As indicated in the previous response, the 5A6 indicates that the range is in the Sabbath mode (SAb). The image below shows the information on this mode for your range. Press the CLOCK button and hold it for 3 deliberate seconds to cancel this Sabbath mode. The control should then work normally. what does the f-2 error code on my maytag oven mean?
26 Jun 2010
What does the SAB error code mean on my Maytag ...
1 answer
1 Jan 2010
How do I cancel the Sabbath mode on my Maytag range?
30 Dec 2008
What does an SA6 (or 5A6) error code mean on my ...
1 answer
13 Nov 2008
More results from www.shopyourway.com
Maytag Oven SAb error code - YouTube
? 0:54
https://www.youtube.com/watch?v=XUP1BOzqPUo Jan 1, 2014 - Uploaded by Life With Christ
The SAb error code will freeze your oven functionality and you will not be able to cook or program the oven ... Oven Repair including Ranges and Cooktops
Mar 12, 2018 | Kitchen Ranges
Stove works oven wont turn on. now is reading fault code (SA6). what does that mean? and how do I fix the proble
If sab Push and hold clock button in for a few seconds.When it clears, the oven should work fine. God-Bless! Just let me know if that works. It is in sabbath mode. Research said it is sab not sa6,
Dec 28, 2015 | Maytag Range Oven Part - Oven Temperature...
How to clear or reset SA6 code on digital display? none of the button function works.
SAB (which is probably the display message) means that the range is in Sabbath mode. The unit believes that you want the range to maintain whatever the previous settings were for the next 24-36 hours. (This is useful for those who do no work on the Sabbath but wish to keep a dish hot in a low oven for the period.)
Providing the model number would be more helpful than the serial number. The manual for the range will explain how to toggle on and off the Sabbath mode. Since you don't give your range's manufacturer and model number, I can't be sure how to disable the mode. However, on some models, press and hold the Timed oven "Cook Time" and "Delay start" buttons. For some Maytag ovens, just press and hold the Clock key.
I hope this helps.
Oct 20, 2015 | Kitchen Ranges
Display is showing 5 ab on panel. model maytag MER5751BAW
It is actually displaying Sab, stands for Sabbath mode. Check your user manual and see how to turn the Sabbath mode off. This should solve your problem. Hope this helps
Sep 01, 2011 | Maytag 30" Self-Cleaning Freestanding...
I AM GETTING A ERROR CODE ON MY STOVE SAB OR SA6 HOWEVER NONE OF THE BUTTONS WORK
This is the Sabbath feature on my Kenmore Elite Electric Slide in Range. My oven manual says to press both the (timed oven) "cook time" button and the "delay start" button at the same time for approx. 3 seconds and this should shut down the feature. I had the same problem, tried the above and it worked.
Mar 06, 2011 | Kenmore 46564 / 46565 / 465 / 6646569...
Has a error mess that reads SAb
"Sab" actually stands for "Sabbath Mode". This mode is set for those religions that honor the sabbath, effectively disabling the range for up to 72 hours. Unplugging it or turning off the breaker will not reset it. The following link explains:
http://www.fixya.com/support/r430549-sabb_or_sab_error
In order to unlock the controls you will need to reference your owner's manual. The model number you have this listed under requires you to press and hold the START button for 5 seconds to lock/unlock the controls. On other models, you press and hold the CLOCK button for 3 to 5 seconds.
If this is not the correct model number, or if you do not have an owner's manual, please post back with the model number so that I may assist you better. I hope I've been helpful to you.
Aug 17, 2009 | Whirlpool GR465LXLS Electric Kitchen Range
I have a code on sceen 5a6 what dose that mean
What's probably being displayed is actually "Sab". This is an indication that the range is in "Sabbath Mode". This mode is set for those religions that honor the sabbath and disables the oven for about 72 hours. Unplugging the range will not clear this. It can sometimes be set accidentally following a power outage or inadvertently hitting the wrong button on the control panel.
If the model number you have this listed under is correct, you can cancel Sabbath Mode by pressing and holding the "CLOCK" button on the control panel for 5 seconds. If you refer to your Owner's Manual the instructions are listed under the Oven features section.
If you do not have a manual, you can go to managemyhome.com and download one for FREE.
If you have any questions, please let me know. If the model number is incorrect, please post back with the correct model number so that I may provide you with better assistance. I hope you find this information helpful.
Aug 14, 2009 | Amana AGR5715QDS Gas Kitchen Range
Maytag oven - error message sa6. oven wont work. stove top works
If you are receiving the SAb code your range is in the sabbath mode. I don't know what this means but it is really easy to fix. Press and hold the clock button for 5 seconds. The code will flash, let go and it is reset.
May 04, 2008 | Maytag Kitchen Ranges
PANASONIC SA6 PUK CODE
go on the site
Feb 20, 2008 | Cell Phones
Clock now shows an SA6 error code
Hold down the clock key for more than 5 seconds, did the trick!
Nov 20, 2007 | Magic Chef CER3725AA Electric Kitchen...
Kitchen Ranges Logo
650 people viewed this question
Top Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Andrew Taylor
Andrew Taylor
Are you a Kitchen Range Expert? Answer questions, earn points and help others
