Question about Connex Radio Communications
I have a connex night runner and the lights went out on the face. How do I fix it. Or is it even worth fixing
Posted by Chad Belden on
gtmnow
    Problem Solver:
  • 13 Answers
Small watch like battery located behind channel selector
Posted on Jul 01, 2015
Plugged in heard talk then nothing lights still worked but no power signal. help
probably sent enough power thru the reverse polarity diode to burd it but still have enough to keep lights on.
Jun 28, 2014 | Connex Cx-366ce Night Runner 40ch Cb...
I have a cx-366ce cb cannot hear talking what is wrong
Is squelch turned too high that it is blocking too many signals?
Otherwise, it could be a faulty cable on the mic as the PTT button disconnects the speaker on the CB and a broken wire can cause the speaker to be disconnected.
No longer has picture - voice still working - can it be fixed or is it worth fixing?
Not knowing brand and model number most of these sets have a 4-5 year life and parts for a set of this age may not be available.
The risk in repairing a set this old is it may just fail again and again.
Dec 23, 2012 | Televison & Video
1 mile range on cb
Check cables and connectors.
• check antenna SWR,
A good SWR ranges from 1.2 to 1.5.
• check power output.
Jul 27, 2012 | Connex Cx-366ce Night Runner 40ch Cb...
Radio worked fine when bought 2 days worth went to key up mike only sound is a sustained whistle sound,took to repair shop had fixed guy said he rebuilt talkback worked again 2 days same result sustained...
Do it have a relay mod for the talkback if so take that thing out. use the normal talkback. We are in TX.. no charge to check out.. I would check to make sure it has just plain normal talkback, and no other mods done first.. any other mods done??
Mar 19, 2011 | Connex Radio Communications
No pic, no sound
if it no has any kind of liquid damaged your best bet is de deflection board power supply and or fuse. i need to know if thered light lit or blinks if so how many times
Jun 10, 2007 | Sony KP-51WS510 51" Rear Projection...
Radio Communications Logo
130 people viewed this question
Top Connex Radio Communications Experts
Tony Raia
Marvin
Marvin
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
