Question about Golf
Recently purchased a used 1995 Western 36v golf cart. Installed new batteries, but cart wont run. Solenoid is good. Help or link to a wiring diagram or service manual would be greatly appreciated.
Posted by Stacy Makerov on
johnny rebel
    Top Expert:
  • 10,875 Answers
3 Related Answers
mr1967mejias
FastHarley
  • 751 Answers
SOURCE: 36 volt ezgo
First of all, lift rear axle off the ground and place blocks or jack stands underneath. Check to see if you have 36 volts On your batteries. Now you want to run a jumper across the big cables on the solenoid. Press the accelerator and the motor should engage. Clicking is a pretty sure sign that the solenoid is bad. Please let me know if this is useful. I can further elaborate more troubleshooting if this doesn't solve your problem.
Posted on Nov 09, 2014
daytoncom93026
L Heme
  • 395 Answers
SOURCE: I need a wiring schematic for a 2002 ULB Vantage golf cart. It has new batteries but does not go forward or reverse. It has power to the motor.
Check with Alpine Auto Werkstatt in Dayton, TN. They have the answer
Posted on Feb 02, 2015
gbob59
  • 3063 Answers
SOURCE: On my 36V club cart the cable from the motor to the battery gets extremely hot
Sounds like either the cable connections at the battery/s need to be cleaned to bright metal or this is a sign the controller, and or drive motor is beginning to fail. Hot means something close to a "short" is drawing a very high current.
Posted on May 05, 2015
Yamaha electric golf cart 36v at motor but won't move reverse buzzer works has new batteries solenoid clicks Any ideas
I would make sure that the solenoid IS working even if it's clicking.
Make sure that the positive voltage is on the field side when it clicks.
Jun 26, 2017 | Golf
Electric golf cart won't run on cold mornings. I hear solenoid click but nothing happens. When the temp warms up, it runs normal. I replaced controller, solenoid, speed control and ITS & switch.
Depends on how cold it's getting outside. Cold weather is ******* a battery. Try load testing your batteries. That "clicking" noise makes me believe that it's trying to start, but it's not pulling enough amps. Considering everything that you've already replaced, I would start there. Assuming you've already made certain all of your connections are good. Also, make sure the ground wire for your electrical system is good. Not loose, corroded, etc...
You can even call the local golf course and ask to speak to the golf cart mechanic. I would get several calls a week from drivers when I worked as a diesel mechanic.
Oct 20, 2016 | Golf
Troubleshooting gad pedal on electric clubcar
Not sure exactly what you mean. A model number will help so I might look at wiring diagram. Is the pedal a variable speed or maybe about 4 different set speeds? The model number will tell me. First thing to check is the battery terminals for good connection with cables and and make sure cables are clean.
Jul 26, 2016 | Golf
Ezgo golf cart solenoid will not work. 36v on battery side 28v on controller side. If the resistor is faulty will this cause the solenoid not to work?? when I push the pedal?
Solenoid valve is the use of electrical energy flowing through the coil generates electromagnetic suction spool (or self-gravity to overcome the spring) attracted Sectional normally open and normally closed two categories typically used to cut off the flow of oil, water, gas and other substances. With pressure, temperature sensors and other electrical equipment to achieve automatic control. Car Diagnostic Tool
Jan 02, 2016 | EZGO 1995-99 DCX600 Controller 600 Amp...
36 volt ezgo
Aug 06, 2014 | Performance Plus Carts EZGO Golf Cart 36...
Club car brake light not working
2008 precedenmt golf cart dash light keep coming off an on
Mar 02, 2013 | Power Equipment Solutions 2002 Club Car DS...
Need battery wiring diagram for 1987 ezgo golf cart
Tell me what cart you have and i can help. Not all carts get wired up the same way as this link demonstrates. In the pix pay close attention to how battery one gets hooked up as this sets the pattern
http://www.updateyourdriver.com/driver/?t202id=211793&t202kw=webcam&gclid=COTM4t-ZsJwCFQxM5QodWjoflQ
Aug 19, 2009 | Electronics - Others
Cannot turn off power
Sounds like you may just have some bare wires touching,Trace the wires from the ignition switch.
Jul 22, 2009 | 3d Rose Londons Times Funny Cow Cartoons -...
Ez Go 28115-G01 battery charger does not work.
I have an EZGO powerwise 36V charger, model 28115-GO3 that was installed onboard a cart. I want to use this charger for another cart, but the charger has 3 wires out. Why 3 wires? One is +, the other -. what do I do with the third wire? The wires are red, black and yellow; two odf the wires are 10-12 gauge, the other is around 16 gauge.
Mar 26, 2009 | Electronics - Others
Golf Logo
1,275 people viewed this question
Top Golf Experts
ray gallant
Kardoc
Bill Boyd
Are you a Golf Expert? Answer questions, earn points and help others
