Question about Roland VersaCAMM VP-540i
Not cutting corners good, media is ruffled around cut.
Have adjusted force and blade
Posted by dirk pearson on
David Payne
    Top Expert:
  • Roland Master
  • 14,162 Answers
Posted on Jun 23, 2015
How tight is tight when adjusting your blade? My blade bends when cutting curves. Thank you
maybe you need to slow down when going around corners, most of the uneven grass cutting around corners is from the lean to the outside of corners
Mar 23, 2013 | Garden
Cuts unevenly
This is probably because the offsetting tapered discs in the dado are not lined up to compliment each other and your dado is tipping more to one side than the other - if the blade was tipping to the left and right the same amount, both sides would cut to the same depth and the deepest part would be right in the middle. In an extreme case, if the blade tipped only to the right and not to the left, then the left side would cut the deepest and the bottom of the cut would curve up (shallower) to the right.
The same effect could be due to your arbor not being set exactly at 0 or 90 degrees. The angle indicator on the saw is usually not very accurate. Put a regular blade in, raise it up all of the way, then check for squareness between the table and the side of the blade (using a known good square). Adjust the tilt until you are good, then put the adjustable dado back in.
Sep 04, 2012 | Oldham 7005012 7 Inch Adjustable Dado...
UNEVEN GRASS CUTTING
The most common cause of uneven grass is tire pressure of the machine. Even though they may look like they have air, when you go around a corner it may droop down on that side. If the mechanism is intact, there is no reason for it to change while riding. Or possibly you have a bent hanger.
Dec 15, 2011 | Garden
I have a craftsman jigsaw(scroll) that I got for Christmas last year. The blade comes out in the middle of my cut some time. Is there a problem with this type of jigsaw?? I have sanded the top of the...
Most of the time the cause for this is applying to much pressure on the blade as you are cutting. Remember, the blade does the cutting and you are guiding the jigsaw around the cut. This can strip the blade and wear the top of the mount. Adjust the way you cut and you should not have any problems.
Aug 26, 2011 | Craftsman Saws
I have an Andis outliner II I purchased a year ago. I recently changed the blade but it won't cut my hair. Do you kow why?
Sometimes the new blades from Andis are not sharpen enough to get that clean cut. also all trimmers need to be readjusted for power and alignment, plus sharpening the blade, it look like you need a complete sharpen & service on your Andis trimmer. check out Manny's Sharpening they have a Mail Order service, the service they provide is fast and they will sharpen make all the adjustment and give your trimmer more power and the blade will cut clean. They will even adjust the blade at your request on how you want that blade to be set at. Line Ups or Fade Cuts and even shave set. Manny's Sharpening been around for over 20 years and they have a very good rating on the net. Check it out Manny's Sharpening
May 21, 2011 | Andis Outliner II Hair Trimmer
Ryobi 7" wet saw. water
Direct the water on to the slate itself just ahead of the cut. When you spray the blade, centrifugal force causes the water to fly back off. Good luck!
Nov 07, 2010 | Garden
Delta 28-185 bandsaw cuts crooked after 4" of straight cut adjustments have been made as per manual
Sounds like your blade is getting hot, causing it to expand, causing it to be too loose. The blade gets hot when it's teeth are rubbing or scraping the material more than they are cutting. . You might see some improvement by increasing the blade tension and feeding the material a bit more aggressively. . But you will see greater improvement by using a blade with fewer teeth. For a given blade, the thicker the material is, the more teeth there are engaged in cutting at the same time, so each tooth gets a smaller share of your feeding force. . The optimum number of teeth that should be engaged in the cut at a time varies by the material, the style, quality and condition of the blade, and the rigidity of the saw---- but you can use 3 to 10 as a rough guide. . Good luck, and thanks for using FixYa. Al Kupchella
Apr 15, 2010 | Delta BS100 Shopmaster 9 Inch Bench Top...
Why my chain saw always cuts at an angle
a lot of people have this problem with a chain saw and cant get a strate cut, most of the time its down to them trying to force the saw through the wood and in doing this the saw cuts around corners as there pull is not square to the cut,, let the saw do the work, not you, if your pulling on the saw to make it cut well then it has a very dull or blunt blade,,,is there any side to side "rock" on the chain in this new bar? how have you sharpend it? dose the chain have the same pitch on both side's? are all the teeth cutting at the same depth? if its cutting around corners it could still be the chain pitch worn out, if so the chain is past its best as well, but most of the time its all down to how hard and how squarely your pulling on the blade when cutting,,,the first thing in logging to lurn is to cut squarely no easy task that! just dont force the saw to cut!! it will cut just as fast or faster without forseing it,, if all this still dont get you cutting right change the chain for a new one,,,the only hard work with a chain saw is holding it up to the tree and humping it around not cutting with it, thats the blade's job to do so the faster you try to make it cut the more out of true the cut go's as all your doing is bending the bar out of alinement,,all in all, its two hands for the job and a very gentle pressure on the saw, start the cut with the blade spinning and dont stop the blade in the wood, cut right through
Mar 28, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Blade guide bushes melt/wear with hard wood
If these bushings are getting that hot, then you may have the wrong speed or a non-optimum blade. The blade pitch (number of teeth per inch) must be lower the thicker the wood is. If there are too many teeth trying to cut at the same time you have to push harder to get enough pressure to cut and that puts more force on the guide bushings. There are a variety of pitches available even for the narrower scrolling blades. If you have to move up to a wider blade, there is a little trick to help you cut a slightly smaller scroll radius - round off the back side of the blade with a sharpening stone.
Also, with oak, you may need to use a slower speed to keep the blade from heating up - although a hot blade will show up as more of a problem with the lower guide bushings only. Your saw might have multiple steps on the pulleys, allowing you to move the belt to a slower speed.
I hope this helps. Thanks for using Fixya. Good luck!
Al K
Mar 21, 2010 | Saws
Dw703 beval adjustment
User manual for adjusting your saw here.
When you set it up, make sure you check for square to the table, square to the fence, and check square for toe-in or at a 45 deg. angle across the blade from the corner where fence meets table, like you would check a radial arm saw. (hold a framing square with one leg against line of fence/table and other leg against blade and inclined 45 to both table and fence. Make sure all three are dead square.
I never found any way to compensate for the play in the blade itself. It seems like the manufacturing tolerances are a little too loose.
You may need a heavier plated blade. You may simply need a different saw. Those Dewalts are great workhorses, and I love the design, but it's my experience that when you're trying to miter hardwoods of any substantial size there's a little bit of drift in the cut as the blade comes through the wood.
You can try cutting at a slower rate.
I've found that makitas are a little more solid through the cut, though I don't like the general ergonomics as much...
Kind of a pain, isn't it?
Well, good luck.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Sep 04, 2009 | Saws
Roland VersaCAMM VP-540i Logo
67 people viewed this question
Top Roland Office Equipment & Supplies Experts
Ekse
Marvin
Marvin
Are you a Roland Office Equipment and Supply Expert? Answer questions, earn points and help others
