Question about Emerson Heating & Cooling
How many btu is model number 10gc13 - Emerson Heating & Cooling
Posted by kevin tobin on
JP Meneide
    Dedicated:
    Visited the website for 20 consecutive days.
  • 483 Answers
Hello Kevin,
It is a 10,000 BTU A/C unit
Good Luck,
JP
Posted on Jun 24, 2015
Mitsubishi Heavy Industries Cassette Out Door Model: FDC506HES. What is the BTU size?
1 ton of ac is 12000 btu. you should probably call mitsubishi they have a tech support that will help you with this. the number is usually in the paperwork that came with the unit. you may find it on the tag where you got the model number
1helpful
Out door unit model number PV-6YARD This model number Air conditioner howmutch Ton
Seems to be 1/2 ton. Please write which brand it belongs to and also indoor model also. If not write BTU. 12,000 BTU = 1TR. Thanks.
I have the Model number and serial number but am unable to find the BTU's on mty furnace...Help please?
if you have the model number of the furnace, then you have the btu input of the furnace. The model number usually starts with letters, then the three numbers following the letters are usually the btu input of the furnace.
For instance if it said 075 then it would have an input rating of 75,000 btu/hr or if it said 125 then it would have an input rating of 125,000 btu/hr.
Hope this helps
What is the seer rating and tonnage of a bryant model fb4anf030
The Tonnage appears to be 2 1/2 ton,
024=24,000 BTU=2ton
030=30,000 BTU=2 1/2ton
036=36,000 BTU= 3ton
I dont think you have the correct Model Number, Look
on the outdoor unit, the model number might start with a 38. Hint Carrier and Bryant Products are the Same, just different nametag
2helpful
2answers
Btu's
That air handler can accamodate different size coils. Look for the coil model number. Also you can look at the outdoor unit model number they should be matched up. There is generally a set of 2-3 numbers in the model numbers that will tell you. xxx036xxx is 36,000 btu. tonnage is 12,000 btu per ton so 36,000 btu's would be 3 tons. xxx040xxx= 40,000btu's or 3.5 tons etc.
Heating & Cooling Logo
Top Emerson Heating & Cooling Experts
Dan Webster
Dan Webster
jdthefixer
shizznat
Level 1 Expert
Are you an Emerson Heating and Cooling Expert? Answer questions, earn points and help others
