Question about NorStar M7310 Phone
DATE AND TIME FROZEN. HOW TO RESET THEM?
Date and time were frozen when arrived Monday. Have reset them numerous times, and whatever I reset them to becomes the new date and time and it will not change until I manually change it again.
Posted by Cindy Billings on
  • Cindy Billings
    Cindy Billings Jun 25, 2015
    The electric in our building went off on the weekend. Now my M7310 phone system is not working properly. The calls in and out seem to be fine, however, the date and time do not change automatically like before. Right now my phone says June 23 at 10:34 am, which is the last time I manually changed it. It is frozen. I've unplugged it, and the reset when all the lights flash does occur, but the date and time do not change. Any suggestions?
5 Related Answers
Anonymous
  • 326 Answers
SOURCE: Changing Time and Date
i had this problem a while ago, you have to set the time from the main phone
Press FEATURE **8463 – Display shows PASSWORD:
Then type in 23646 (Note this number will not show on display)
The display will show hours.
Press CHANGE (or NEXT if you do not need to change the hour).
Enter the hour (00 to 23). If number is less than 13, the display shows AM.
Press CHANGE to select PM.
Press NEXT. The display shows minutes.
Press CHANGE (or NEXT if you do not need to change the minutes).
Enter the minutes (00 to 59).
Press NEXT. The display shows year.
Press CHANGE (or NEXT if you do not need to change the year).
Enter the last two digits of current year.
Press NEXT. The display shows month.
Press CHANGE (or NEXT if you do not need to change the month).
Enter the month (01 to 12).
Press NEXT. The display shows day.
Press CHANGE.
Enter the day of the month (10 to 31)
Press RLS (release) to exit.
Posted on Apr 18, 2008
Anonymous
  • 326 Answers
SOURCE: Setting date & time on M7310
Normal 0 TIME CHANGE PROCEDURE: DONE FROM THE MAINPHONE
The display will shoe hours.
Press CHANGE.
let me know how you get on
Posted on Sep 18, 2008
Anonymous
SOURCE: how too change time
Norstar Merdian Press Feature.
Enter "**8463".
Enter the password (default is 266344). The display shows
Hour: 01
Next Change
Select CHANGE. Display shows:
Hour: __
Cancel
Enter two digits for the hour. Chose AM or PM when Prompted.
Select NEXT.
The display shows:
Minutes: 00
Next Change
Enter the minutes.
Press the RLS button to end, or press NEXT to change the date.
The diplay shows:
Year: 99
Next Change
Enter the two-digit year.
Select NEXT and repeat to change the month and day.
Press the RLS key to save the time and date and exit programming.
Top of Page
Norstar Meridian CICS Time
  • Press "FEAT".
  • Press "*".
  • Press "*".
  • Press "266344" (CONFIG) or "23646" (ADMIN).
  • Enter password "23456" (ADMIN) or "72787" (SCPLUS).
  • You will see "Terminals & Sets".
  • Press "Next" five times.
  • Press "Show"
  • When you see "Hour", press "Change" or "Next" to skip.
  • Type in the hour using military time as a 2 digit number.
  • Press "Next".
  • When you see "Minutes", press "Change" or "Next" to skip.
  • Type in the minutes using a 2 digit number.
  • Press "Next".
Date:
  • When you see "Year", press "Change" or "Next" to skip.
  • Type the year in 2-digit format.
  • Press "Next".
  • When you see "Month", press "Change" or "Next" to skip.
  • Type the month in 2-digit format.
  • Press "Next".
  • When you see "Day", press "Change" or "Next" to skip.
  • Type the day in 7-digit format.
  • Press "Next".
  • When you see "End of List", Press "Rls" to exit.
Top of Page
Nortel Norstar Telephone Systems Changing the time on a Norstar system must be done using a display phone. Using a M7310 or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
  1. To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4"
  2. Enter password (default = 266344) - display should read "Terminals & Sets"
  3. Press "NEXT" 5 times - display should read "Time and Date"
  4. Press "SHOW" - display should read "Hour:___"
  5. Press softkey "CHANGE"
  6. Enter hour - display should read "AM OK or Change"
  7. Select AM or PM
  8. Press "NEXT" - display should read "Minutes:___"
  9. Press softkey "CHANGE"
  10. Enter minutes
  11. Press "NEXT" - display should read "Year:___"
  12. Press softkey "CHANGE"
  13. Enter year
  14. Press "NEXT" - display should read "Month:___"
  15. Press softkey "CHANGE"
  16. Enter month
  17. Press "NEXT" - display should read "Day:___"
  18. Press softkey "CHANGE"
  19. Enter day
  20. Press "NEXT"
Posted on Oct 22, 2008
consultel1
george peters
  • 860 Answers
SOURCE: How to change the time and date on nortel phone
Programming2.gif is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say A. Configuration. The 4 top line/feature keys are now used for programming.
Press "NEXT"(bottom right arrow)
display should read B.General Administration.
Press the show key (top right arrow)
display should read 1.speed dial
Press the next key 2 times(bottom right arrow) .
display should say 3.time and date
display should show current programmed time
Press the Change key
Enter in time in 12 hour format
press ok
press either Am or PM when prompted
press ok
press the Rls key when finished
Posted on Nov 04, 2009
consultel1
george peters
  • 860 Answers
SOURCE: cant change time and date on nortel t7208 phone
Programming on the nortel system is done on M 7310, M 7324, or T 7316 sets only.hopfully the receptionist station has one of the larger sets.
Posted on Apr 15, 2010
Testimonial: "With clarification that I gave on steps I took and what were results within three questions figured out the problem and solved it. Thank you very muc"
Power interruption and now my plug,n go seems to be frozen. Cannot set time or clear anything. Screen reads 9.80 or something close
I had a similar problem with my Bosch wall oven after a recent power outage-restart-outage-restart cycle that lasted only about thirty seconds altogether. The difference would be in that while I could reset all the things like day, date, time, etc., the oven would arbitrarily go off on its own and make up the day, time, date, year, etc., with no apparent correspondance to reality. Here's what I did: I completely shut down the oven at its outside breaker (you will need to do whatever it takes to remove the power from the 'plug-n-go'). I waited five or ten minutes before turning the power back on and resetting the various items. Two days have passed and there have been no more mind-of-its-own excursions into another time zone. Problem solved, unless/until another power outage cycle comes along. Hope this helps, or at least gives you an idea about where to start.
Dec 15, 2014 | Hardware & Accessories
DATE -TIME RESET??
What seems to be the problem with the date and time?
If you want to change the date and time settings, then you can click on the time on the bottom right corner of your screen. There you can change the time and date settings.
Or if date and time are always changing whatever you do then you would need to change the CMOS battery of your computer.
David
Jun 10, 2013 | HP Compaq Presario V2000 Notebook
My cybershot camera has frozen. what do i do?
Try removing the battery fo 15mins. this will reser the camera back to the default. Now go to the camera's Menu to set the Date & Time.
Nov 26, 2012 | Cameras
The display is frozen and I can't get the watch to reset. I was beginning exercising and it is frozen on this screen.
If there are no reactions to any buttons, reset the
wrist unit by pressing all the buttons
simultaneously for two seconds. All other settings
except time and date will be saved.
manual is here
Dec 21, 2010 | Polar F4 Heart Rate Monitor Watch
Date & time.
To reset system time you must be at the attendant station and with the handset cradled:
Dial: #06 4321 1 # (4321 is the default password)
Then:#55 YY, MM, DD, W, HH, MM, # time will be saved and phone will go back to normal operation.
Naming convention:
YY - Last two digits of the year
MM - Month (1-12)
DD - Day of month (1-31)
W - Day of Week (monday = 1.... sunday = 7)
HH - Hour (24hr format)
MM - Minutes (00-59)
ex: To set the time For Monday, Jan. 5, 2009 at 8:31pm I would enter: 09 01 05 1 20 31 #
Good Luck,
BB
Dec 02, 2008 | Samsung Prostar 816 Phone
SHR-2082 RECORDING TIME ZONE FROZEN!
David,
try setting the time to something different (Like a day and hour from the current setting) than the current time and see if that come up if so then set the system to the current time and date and check again, if that solves your problem great if not reset your system and reprogram it.
•Factory Reset Hidden Key :
Mode Key + CH 2
•The Password and all setting
value will return to the initial
default value.
•Default Password is ‘4321’ .
mj
Sep 27, 2008 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
CAMERA WANTS TO RESET TIME DATE INFORMATION
If you have a memory card installed take that out before powering on.
If your screen is frozen then you would have to send it into repairs to have that fixed.
Sep 03, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
System Time/Date in BIOS setup not functional
reset your bios with jumper settings.
Apr 03, 2008 | Computers & Internet
Nintendo ds lite time and date freezing
Call a nintendo help line or exchange it where you purchased the ds and get a new 1 for free.
Dec 28, 2007 | Nintendo DS Lite Console
Frozen Display
The reset will always solve the issue. It may have been due to Electromagnetic Interference or Static Electricity.
You can press and hold ALL buttons at the same time for 10-15 seconds. After that, simply reset the time/date. All saved information will be stored.
If you are still having a problem feel free to contact Polar Customer Support @ www.polarusa.com.
Hope this helps.
Chris @ Polar USA
Nov 08, 2007 | Polar F6 Wrist Watch
NorStar M7310 Phone Logo
Top NorStar Lands Phones Experts
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
