Sony VPL-ES4 Projector Logo
c
chifundo mtambalika Posted on Jun 23, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Sony VPL ES4 switches on quite Ok, but after some seconds the bulb goes off and a red light just blinks
Tried to clean inside,nothing changes.I dont what to do now.
Sajeesh Mv Nair
Level 1:
New Friend:
  • Contributor 16 Answers
  • Posted on Jul 21, 2018
Sajeesh Mv Nair
Contributor
Level 1:
New Friend:
Answers
16
Questions
Helped
12261
Points
45
Jassim
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 04, 2015
Jassim
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1082
Points
Sony VPL-DX100 projector red light blinking first focus coming after 20 second focus off than red light blinking now how to solve this problem
My Sony VPL ES4 switches on quite Ok, but after so - 12_4_2015_6_57_34_am.jpeg
Bernie Corrigan
Level 3:
Master:
  • Sony Master 487 Answers
  • Posted on Jun 23, 2015
Bernie Corrigan
Sony Master
Level 3:
Master:
Answers
487
Questions
Helped
130437
Points
1204
Try Sony support at: http://pro.sony.com/bbsc/ssr/cat-projectors/cat-ultrahires/?XID=O:+sony%20projectors:BPSEG_sxrd_gglsrch:b&adparam=sem154p73387g-c&k_id=890f09c2-1e8c-4d5a-bf72-bdd6f6cb7721
On/Standby light flashes red four times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
1helpful
I have a Sony projector VPL-ES4 and the ON / Standby red flashes 6 flashes. I got the lamp, I cleaned the air filter, I tried to reset Left Right Enter key and the problem still persists. Can you help?...
check a small bord under the mother bord calld air sensor
its look`s like a transistor check the divice properly and change the projector frimware through computer
We have sony vples4 projector ,when i turned on it ,light is glow but after 5 minitus total projetcor is turned off
Does it switch off with an error message or the lights indicating a problem. is the power saving feature switched on.
is the air filter cleaned.
I have a sony SVGA VPL-ES4, when i turn it on it comes on only for a little while then goes off and the power button has this continuos blinking red button. HELP please..
hi,
Do one thing try to reset the lamp hour timer. for the same do the following.
Press the following keys on the remote in the following order for less than 5 seconds each.( on standby mode)
RESET then LEFT ARROW then RIGHT ARROW then ENTER
Remember on thing lamp reset is recommended only after replacing the lamp. if works try to replace the lamp as soon as possible.
ok
Blinking yellow light for lamp cover and will not start up
check that the lamp cover is not bent up slightly due to old age, and the little switch underneath is activated when the cover is installed
Focus Problem
the lamp of the device may be going to end its life, need replacement.
15helpful
3answers
Vpl-es4 sony projector-frequency out of range
Pl. send me solution. I am stuck with problem
vpl-es4 sony projector-frequency out of range.
Top Sony Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
