Durabrand DUR-1700 Portable DVD Player Logo
Question about Durabrand DUR-1700 Portable DVD Player
Portable DVD player no pic or sound but lights show it's getting power and charging battery
Posted by Sue Bois Buck Kesler on
5 Related Answers
Anonymous
  • 3130 Answers
SOURCE: need accessories for portable dvd player...
I was tol Funi makes the Durabrand for WalMart, Try this addy http://www.funai-corp.com/support/contact.asp Good Luck
Posted on Mar 19, 2007
Anonymous
SOURCE: DUR-7 portable dvd player battery life?
Wal-mart does sell replacement batteries. http://www.walmart.com/catalog/product.do?product_id=2350787 For this particular unit. However; in the future I would suggest researching a particular item before buying esp from Wal-mart. As Durabrand doesn't even have a website.
Posted on Dec 04, 2007
Anonymous
  • 3 Answers
SOURCE: Durabrand bat-09 battery not holding charge
I had the same problem. I wrote to Walmart.com corporate. The contact us section. They called my local store who replaced my machine with a magnavox.
Posted on Dec 05, 2008
Anonymous
  • 22 Answers
SOURCE: Need replacement battery for Durabrand Portable DVD Player
Have you tried Ebay? If you used to proper charger, you shouldn't be able to "overcharge" the battery unles the charging circuit is bad. When battery is attached, will the player "ON" lite come on? Will it try to play a DVD/CD ?
Posted on Dec 29, 2008
Anonymous
SOURCE: Looking for a replacement battery for Durabrand PDB-702, does not hold charge
Hi... I have a battery from a unit that has an unrepairable AC power connection on the DVD player.... Interested?
Posted on Mar 05, 2009
Power light on but not charge light
the battery cell s damaged... the system will work on the power from supply.. please check whether the charging symbol is present on the battery icon which is in the system tray ( bottom left side of the window).. if its there then the charge indication led is damaged which can be easily repaired
My portable coby dvd player wont play with its rechargeable battery after bein charged, the light was blinking and now green but when i take off the adapter and leave the battery it wont turn on?what do i...
Take out the litium battery.Plug in the charger adaptor alone to get power,see if the portable DVD player work.Yes,than the litium battery is dead,not taking in any charges.Tries websites like Partstore.com,Amazon.com,Ebay.com to buy a new exact litium battery or a compatible litium battery.
2helpful
2answers
I can't figure out how to charge my Sony portable DVD extra battery
There should be a external port,plug in,plug the tranformer to the power source now,should have
indicator light will light up.Fully charge light will go out.Have to put it in the DVD player to charge that the extra battery only way.
Main screen has no picture
go to you`r pics and change wich pic you want.
Dvd portable
OK...all you have to do is to change the flex cable which is connected from the mother board to the screen or LCD of your portable DVD..i am the is the problem of your Portable DVD.
Battery won't charge
Borrow or get a cheap volt meter to see if the power supply is working. Insert one probe on the inside, and one on the outside to see what is going on inside the power supply/charger.
Does the power supply hum or get warm? If not, it was probably made pre-broken at the factory in china. Either that or it's power lead has a break, it's power output jack or where it connects to the main board on your portable DVD player.
-Pro Hack
2answers
Mintek Portable DVD Player
The overall life over portable DVD player batteries is terrible.
Here is some information on ordering a battery
How do I charge it? PLEASE HELP!!!!!
If you put the battery in the player and then plug in the player it should charge the battery. Be sure to leave it until the light in the front of the player shows green.
2answers
Insignia IS-PD040922 portable dvd player
The batteries are not being charge,it might be bacuse you have the wrong ac adapter,you should get the original to start then let the batterys charge for at least 5 hours or until the red light stopr blinking.You can find more inf.here http://www.insignia-products.com/p-31-insignia-7-169-widescreen-portable-dvd-player.aspx
Top Durabrand Televison & Video Experts
Jaime Hernandez
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
