Proscan 7-Inch Android Internet Tablet, Capacitive Touch Screen, Android 4.1 Jelly Bean, with Included Case and Keyboard Logo
C
Carrie Bailey Posted on Jun 22, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I bought sd card for it. want to download apps to it not to internal or nand memory. help please
Captain Neal
Level 2:
Novelist:
  • Expert 174 Answers
  • Posted on Jun 26, 2015
Captain Neal
Expert
Level 2:
Novelist:
Answers
174
Questions
Helped
64420
Points
487
That is not an easy thing to do. The best you can do is download the apps to the internal memory and then touch them one by one and see if there is an option to MOVE them to the external SD card. It has been my experience that not very many can be moved.
How do I move apps, pics, etc to SD card? Internal storage is full
For Android users, get the app Android Assistant and run it, use the Tools tab and choose the tool named "APP2SD" and choose an app from the list. When the app description appears, click on the STORAGE button and then click on CHANGE and click on SD to move the app from "Internal" to "SD card". Wait for the app to finish being moved, then back out to the list of apps that can still be moved to the SD card and do the next app. Be aware that when apps get updated, they will move back to the internal memory, so I usually check with APP2SD about once a week and move things as needed to my SD card. For space on my SD card, I chose a 128GB micro SD card and I've only filled it about 1/4th of the way over the past year. This is the safest way to move things because Android Assistant will only list the apps that can be safely moved to the SD card. Some built-in phone apps must stay on the phone's internal memory to keep working, and those cannot be moved and won't be shown by the APP2SD tool.
The Android Assistant also has a "Cache Clear" option on the Monitor tab that helps free up internal memory on your phone when you run it (cache clear). The app (Android Assistant) may tell you it needs access to stuff so it can clear the cache. Do what it says to give it access, then go back and tell it to clear cache and it will free up some more internal memory. Cache items will be refilled as and when each app gets used, so if memory runs short again, you might need to do this "as-needed".
I paid the cheap price for Android Assistant Pro so I wouldn't accidentally click on advertisements that pay for the free version. It find the app very helpful.
TIP: You can also set MANY apps to PUT their things directly to the SD card instead of internal memory! Yay! I did this with my camera app and it REALLY helps by having photos and videos sent directly to the SD card so I don't have to keep moving them around.
We have a lenovo tab2 A8, with a 64 GB microSD card installed. With both netflix & amazon prime video, in options, there is no selection to download to the SD card instead of the internal storage.
First, go to Settings > Storage and check if the "Default write disk" is set to "SD card". Then go to Settings > Apps and swipe to the left until you get to "SD card". Below will be all the Apps that can be be moved to the external SD card. Click in the box on the right and another page will come up. About in the middle of the page will be "MOVE TO SD CARD" tab. Tap on it and wait until it finishes. Then go back and pick another App to move. You should be able to download apps directly to the external SD card. I haven't done that on this device and not all apps will download to the external SD card (the app maker can restrict downloads to only the internal memory. This tablet is one of the rare few Android devices that allow moving Apps to external memory.
2helpful
3answers
My tablet keeps giving me error message. Insuficcant space on tablet to download apps
This means the internal memory is full and the only way to add apps is to uninstall other apps that you have installed. Check to see if you have apps you no longer use and uninstall them.
Not downloading to the sd card
If you are referring to apps you are downloading, that is probably correct. Most apps will not use the SD card to run (or load). It takes more programming for apps to use the SD card than not to, and since many users do not have an SD card installed, most apps won't use it. That is the falsehood that comes with tablets and eReaders. Users are led to believe that even though the tablet may not have a lot of internal memory that they can add an SD card. That works fine for personal files and photos, but not for apps and their data. Users need to know that if they want a lot of apps on their tablet, they need a tablet with a boatload of internal memory.
How do I transfer from nand to sd
Hi
If your SD card is not recognised there are possibilities:
1. The manual - I'l give the link later in case yours is mislaid - only mentions "Micro SD" up to 32Gb. Sometimes these cards can be the SDHC category and these are not always accepted in devices designed for SD only. They look identical so make sure yours doesn't say SDHC.
2. The file format on the card can be significant. It needs to be a format compatible with the phone. If you have no other data on the card, it might be easiest to see if the phone will format it.
3. Of course it might be a faulty card - can you test it elsewhere?
The link for the manual mentioned above is here:
Proscan Media Tablets eBooks ReadersInstructions Manuals Quick Start...
Its about 15th down the list and will download direct to your computer.
With regard to downloading from nand to SD card, is this essential? If you have a micro USB to normal USB, then you should be able to use a computer to take data from the nand. The nand would show up as a drive in "My Computer".
Hope this is helpful, if so would you please register that with Fixya
Cheers
How to set memory card as default memory storage
Download Titanium back up. it has all you need you can move all the apps to sd card including built in apps (the ones that can not be unistalled)
Caution: your phone has to be rooted juts google how it can be done in case you are not rooted yet. and be carefull while moving apps some apps can cause damage to your phone if moved to sd card. just move the downloaded ones and some few like photo viewer, galary, music player and the like
Bought a 32GB sd card for Azpen A727 do not know how to transfer apps or downloads to card?
Although the Android phones and tablets can add (micro) SD cards, that will not extend the internal memory. You should see the SD card as a extra hard disk. Here you can hold pictures and music. As soon as you installed extra apps, and the phone or tablet is telling you the memory is full, you only can free memory, by deleting apps from the main memory.
If you thought I can buy a phone or tablet with less memory, because the SD cards are very cheap and will extend the internal memory, you thought wrong.
You can't transfer an app to the memory card and still use it as if it was in the main memory.
How do I move memory in my Nextbook 8se premium around to better manage it?
As far as i know this meathod usually works with apps. First you go to settings, second you go to storage, third you go to something like apps, fourth you select an app, fifth you select move to SD card or move to internal memory depending on where you have your data saved. I hope this helps anyone with this problem, im no expert but i will try my best to help
Top Proscan Tablets & eReaders Experts
 Mikey
Mikey
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you a Proscan Tablet and eReader Expert? Answer questions, earn points and help others
