NOT A PC QUESTION. Si-Tex 525 ADF Wiring schematic
The pins connecting the power cable to the unit separated. The power cable only has red and black wires but Which of the three pin locations are used for the black and red power wires?
Posted by William Andersen on
Lars Olsson
    Brigadier General:
  • 3,400 Answers
I have a very old Si-tex pro II finder that im trying to get running can any give me a diagrame of how the wiring. the coulors of each wire does what? witch plug/wires runs to the tranducer??? Thanks Sam
Hello, Ticle33 did you ever get he hold of a wiring diagram for the si-tex profish II? I am in the same situation and cannot find one. Hope to hear from you. Thanks /Tom
I have a SI-TEX black box receiver and I'd like to connect it to a Garmin GPS chartplotter. The SI-TEX black box receiver instructions at one point say:"If the GPS has a NMEA output (or NMEA REF) connect...
Yes, the NMEA- output (I think you lefy uot the "-" in your questoin), anyway, the NMEA - or NMEA negative or NMEA ref is hooked to battery supply ground.
Dont forget to program the Garmin to look for 48,000 baud data.
Jan 10, 2010 • Boating
Proper connection
if u look real close to the pins on the board they will say pwd led and power sw ect ect please keep me posted if you need more help identifying these pins
Power connection for L365 Fish finder
Fuses and Breakers
Attach the red or positive wire to a 5 amp circuit breaker. If the unit is connected directly to the boat’s battery, include a 2 amp in-line fuse. (In-line fuses are available at most marine supply stores.) The power cable includes a smaller "shield" wire. Connect this to a good ground.
Extending the Power Cable
If you need to extend the power wiring by more than 10 feet, use a larger wire size. This will allow the wires to deliver the correct voltage in spite of the longer wire distance. For runs of 20 to 35 feet, use #14 AWG cable. If you extend the power wiring, be sure all electrical connections are solid and durable. Soldering is the best way to make these connections. Insulate all connections using heat-shrink tubing or electrical tape. You may also use crimp connectors or a terminal strip, but be sure to use good-quality marine-grade parts.
Internal wiring
Hi - I have a Garmin GPS 126 in bits on my desk ready for a new cable as the socket in the back has some broken pins.
Also refer to the Garmin GPS to PC Wiring Instructions here on the Garmin site: http://www8.garmin.com/support/faqs/faq.jsp?faq=68
The internal 8 pin white connector on to the back of the circuit board is as follows:
1 Red Positive
2 Black Negative
3 Yellow Data Out
4 Green Data In
5 not used
6 not used
7 White Alarm
All the best, Tony at KiwiGPS, New Zealand
9helpful
5answers
HP 5470c - No power
I've done it, using an adjustable power supply all i needed was 12VDC - 2Amp, the power connector going to the scanner is a 4 pin mini-DIN male, so i've ripped of the cable from the original bad power module, cable has inside 2 wires one black one white and a shielding. Black and schielding are connected together and are going to the minus, the white one is going to +12V
guess what? .... my scanner is working again
2answers
SI-TEX MAX 10 NT
Yes, they are. Call SITEX 727-576-5995 x139
Computer cable
I don't know the answer to this because I am looking for the same thing.This is the answer I got from Si-Tex: You are going to need a cable, cble-6pf-sit. This cable will plug into your GPS-90, on the other end is bare wires. You are going to wire this into the pc somehow. (somehow?)That's the part i'm interested in the most! I ordered the cable can find nothing that shows how to wire it. I assume that it's wired to a db9 serial connector but have no idea what the pinout connections are. If you find out please let me know.
Computers & Internet Logo
Ekse
