Low volume beep sound every 3 minutes from rear of lg. Had previous service, and needed to change the filter. This time the filter change does not stop the beep.
just do the volume the equalization. Once the Bluetooth is on just click the volume (+) until you hear a beep then click volume (-) until you hear a beep, this should equalize your volume. and give you equal sound from both of you earbud.
setting the clock:
1. Press the DISP and by press and hold for more then 1 second.
2. Press the >>' to adjust the hour.
3. Press the '<< to adjust the minute.
checking the clock:
You can see the clock pressing the DISP (DISP. on the remote control).
Adjusting the beep sound
1 Press the SEL for more then 2 seconds
"BEEP ALL" or "BEEP 2ND" appear
2. Press the VOL+/- (Press the VOLUME A V on the remote control) to select beep sound.
BEEP ALL: When any button is pressed, beep sound.
BEEP 2ND: When a key is long pressed (1sec), beep sound.
Answer taken from LG documentation
As for the alarm. I found no documentation that you can set an alarm on your car radio.
To turn off the beep on the keypad beep or voice on an LG Xenon, go to menu; settings; sound; volume. From there you can raise or lower the volume or mute the keypad and other sounds.
Usually that "beep" alert is an indication that your phone is NOT on vibrate, but on "beep". Check your side volume keys and make sure that your setting is on vibrate, then click "ok" to confirm your changed preference.
For the beep you go into the tools menu (bottom right icon) from there go to calls and in that sub menu go to "minute minder" and turn off as for the screen lock I think you can change the time but your stuck with it. i hope that helps some.
Go to Settings > Sound > Volume > Master Volume > It should say "One Beep". Then press the right arrow button and it will change settings. Change it to the Level volume option. You should have your sound back.
