Pool & Spa Logo
r
rhonda fontenot Posted on Jun 20, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why its stays on sleep mode
I cant get the system off of sleep mode
maxcomtest
Level 2:
New Friend:
  • Expert 53 Answers
  • Posted on Jun 28, 2015
maxcomtest
Expert
Level 2:
New Friend:
Answers
53
Questions
0
Helped
19463
Points
392
David Payne
Level 3:
Top Expert:
  • Master 14,162 Answers
  • Posted on Jun 20, 2015
David Payne
Master
Level 3:
Top Expert:
Answers
14162
Questions
0
Helped
2997953
Points
455836
I have a Intex CG-26670. but for some reason i cant get it to run. it only starts up and blink 00. but i cant set the time on it. nothing happens
This might be saying you need to wait 24 hours before it runs:
7. Stand-by/power saving mode: • When the cycle ends, the green "SLEEP" indicator on the control panel lights up and the LED display flashes "93". The system is now in Stand-By mode. After a while, it shuts down and sets itself in a Power Saving mode. The system will automatically turn itself back on in 24 hours, starting its daily cycle of chlorine production. • The "SLEEP" indicator stays on, while the system is in the Power Saving mode. The LED display however, goes blank after 5 minutes. Press any button ( or ) to view the last LED code.
From the manual:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&ved=2ahUKEwinsvC4norqAhWNUt8KHSLlA3QQFjAUegQIBxAB&url=https%3A%2F%2Fintexwetset.co.uk%2Fwp-content%2Fuploads%2Fsites%2F2%2F2019%2F04%2F26668-26670-ECO5220-6220-ECO5230-6230-1.pdf&usg=AOvVaw2zbAebQw6eyqj-dBf6lIdF
1helpful
Prostart 6 button in sleep mode
Sleep mode is a convenient power-saving feature used on both laptops and desktop computers. This feature powers down hard disks, monitors, wireless devices and any other power-consuming peripherals without turning the unit completely off and necessitating a reboot. Sleep mode can prevent battery drain if using a laptop or mobile device while away from the power supply. This mode is useful when quick access to a computer is needed, but can be irritating if the sleep mode takes a long time to come back from. It is simple to turn sleep mode off, based on the operating system being used.
Go to the "Start" button, then click on "Control Panel." In the control panel screen, click "System and Maintenance," then click on "Power Options." This brings you to the "Select a power plan" page. From the "Select a power plan" page, select the option that says "Change plan settings." This changes the settings on the currently selected plan. Select the "Change advanced power settings" option. Click "Sleep" and then click on "Sleep After" to expand it. If using a laptop or mobile PC, click "On battery" and "Plugged in," then select the "Never" option. This turns off sleep mode for both battery and AC use. If you are using a desktop computer, click "Setting," click the arrow and then click "Never" to turn off sleep mode. Click "OK," then click "Save changes" to save the modification. b> Turning Off Sleep Mode - Mac OS b> Click on the Apple logo at the upper left corner of the screen to open the menu and select the "System Preferences" option. From the "System Preferences" screen, click on "Energy Saver." If you are using a desktop, select "Power Adapter" in the top drop-down menu. In the second drop-down menu, select "Custom." Highlight the "Sleep" tab, then adjust the top slider to the far right, marked "Never." I f you wish the display to stay on, adjust the bottom slider to "Never." Click the red button on the upper left side of the "Energy Saver" screen. If you are using a mobile product or laptop, follow step 2 and select "Battery" from the top drop-down menu. Repeat step 3 to change the settings for battery use. Hope this helps.
Before while watching TV a message comes up saying it will go into sleep mode, now it doesnt have a picture screen at all
depending on the model number set is not making it full on--something is causing the set to shutdown for protection.
Monitor automatically sleeps on startup.PLEASE HELP!!!!!!! im running a Dell dimension 8100 .thank you
can you get it out of sleep mode? if so then change your power settings.... you may also be in a mode that the monitor cant support try going into safemode to see if stays on ... if it does it could be two things..... the res is Too high or there is a program that is making it go to sleep......if you have anymore information or would like more help reply here or e-mail me at [email protected]
2helpful
3answers
Need help monitor stays in sleep mode... :(
power down, everything, leave it off for a few minutes, turn it back on.. when it gets booted, disable sleep mode option in advanced power features.
1helpful
Sleep mode
usually, to get a PC out of sleep mode, you either press the ESC key, press the power button a bit quickly, or press the sleep key agian. It really depends on the system. Try any of those to see if it helps.
-Chad
Computor won't stay in sleep state.
remove the serial bus cable and reinstalled the software that came with it,itmay be infectted by virus
Vista wont start up
To remove the sleep mode: right click the desktop and select Personalize, Click screen saver, at the bottom of that window you'll see "Change Power Settings" Click on that. Next to the left side of the window click on "Change when the computer goes to sleep and change the setting to "Never".. As far as why its doing it is unclear without hands on work, but you should have warranty for it. Tell them to fix it or try a differ brand of PC.
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
