Question about Motorola Mobility H700 Wireless Headset
Motorola H700 hi how do i piar my h700 with my krazer
Posted by jush on
  • skrivanftld Apr 25, 2008
    My H700 won't pair up with my motorola L6 and I lost the instruction manual.
  • Anonymous Apr 25, 2008
    how to put my h700 in to paring mode
Anonymous
To put the H700 in pairing mode, have the boom closed and hold down the call button. The light should turn purple, then open the boom. Connect to your phone.
Posted on Nov 24, 2008
Anonymous
Remove all
Posted on Apr 23, 2008
Anonymous
  • 3 Answers
I found the motorola H700 quick guide online and it fixed my problem. Check it out here: http://www.motorola.com/mdirect/manuals/QG-H700_9499A88O.pdf
Posted on Aug 17, 2008
How do i put the motorola h700 in pairing mode
Hi terantra,
I would like to assist you with your Motorola H700 headset, Please see steps below.
  • Make sure that there are no other Bluetooth devices in the area.
  • Now set the device that you want your Motorola H700 to pair with make sure that it is detecting devices.
  • Now on your H700 Motorola press and Hold down the Multifunction Button on it, and open the mouth piece.
  • This should be detected right away by the device that you are pairing the with the H700, the pairing Code for this H700 will "0000"
I hope that his will be of help regarding your concern.
Have a nice day,
mvincent
Apr 22, 2011 | Motorola Mobility H700 Wireless Headset
Problem with Blackberry Pearl 8100
Did you try deleting all devices paired and then try pairing again?
May 20, 2008 | Motorola Mobility H700 Wireless Headset
I changed phones and do not have the passkey for H700?
Hi,the passkey for your h700 headset is "0000".this is the default passkey which will work for the pairing of your phone with the headset.
Thanks and take care
Apr 30, 2010 | Motorola Mobility H700 Wireless Headset
Caller unable to hear me while using the H700 headset.
Hi there , to solve this proble since you have the headset over 18 months you need to change the internal battary the life time for these handset battery up to 24 months try to replace it by take it to cellphone shop and im sure you be happy.
Nov 30, 2009 | Motorola Mobility H700 Wireless Headset
PIARING MY MOTOROLA RAZOR V3 WITH MY MOTOPURE H12
turn your bluetooth on and on your phone go to bluetooh or settings(if not under bluetooth) and select trusted devices or pair devices, then on the left or right corner it will say (search) once you have found your bluetooth it will say(motopure h12) select and then it will say pair device and you put in the code that came and your instructions and your good to go.
Feb 27, 2009 | Motorola Mobility Motopure H12 Bluetooth...
Won't detect Motorola H700
Hi David, I want you to go to this link for your nokia E65. Click the link.
http://europe.nokia.com/link?cid=PLAIN_TEXT_119729
On the left side of the page click Demos
When the demo window opens click, Select Demos button.
Scroll through the list until you see Sending Via bluetooth.
Follow the interactive instruction to connect to your H700.
You'll need to set your H700 into pairing mode when searching for the bluetooth H700.
It might be a good idea to book mark the main page.
Good Luck! Take your time.
Mike
Apr 04, 2008 | Motorola Mobility H700 Wireless Headset
I need to set up bluetooth
These will help you.
H700 How to guide
H700 Quick start guide
Good luck and enjoy your new headset!
Dec 14, 2007 | Motorola Mobility H700 Wireless Headset
Path key #1234 not working
The Motorola krazer phone is not on the compatibility list. The only Motorola RAZRs on the list are the V3, V3i, V3m, and V3x. Check the outdated list at http://www.kenwood.com/bt/bt100/
Nov 24, 2007 | Kenwood KCA-BT100 Wireless Headset
Help needed in paring my H700
In order to pair with this device you must follow these steps: 1. Close the mike on the H700 2. Hold the center call button on the H700 until the ring in the center turns violet. 3. Open the mike on the H700 4. Have your phone search for bluetooth devices and follow the propmts 5. If your phone requests a passkey, enter 0000 This is the default for all Motorola devices Hope this helps.
Apr 01, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
478 people viewed this question
Top Motorola Mobility Radio Communications Experts
Dennis
sandyp4ever
sandyp4ever
Level 1 Expert
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
