Hearing a double beep three times after key turned off. NO AC OR HEATER HOOKED UP. All parking lights work, headlights work, dome light works, all blinkers, high beam and flashers work as well as most systems lights on dash but no dash lights.Believe ground is from exterior bulbs illumination. Even with radio unplugged dash stays off, with lights off still no dash lights. Fuses under hood 30-40-50 good nothing in 60amp, rechecked radio hookup all good, repaired two door switches that were shorting, still no illumination on dash. Have power on RED/YELLOW when switched turned on, also shows power on RED/GREEN wire when switched turned on. Have wiring diagram but unable to find where power is coming from unless back feed.Have worked a week on it to no avail, sure could use some help. Did a code check and only blinked 1 2 and cleared the other beeps I was getting, the ground on RED/GREEN is when it's turned off, goes to power when turned on when unattached, have jumped 2-3 with no luck, just to clarify. Thanks
SOURCE: gauge lights not working.
Solved the problem -on of the fuses in the relay box under the hood was bad - Although it is not marked well - It says park and horn????
SOURCE: headlights, dome lights, and radio shut off on my 1990 bronco!
possibly the dimmer switch on the floor? happened on my 91 half ton dims didnt work but brights did and then they cut out altogether. a little water goes a long way
SOURCE: headlights and dash light dont work
You would have to check and see if you are getting any power out of the light switch. There is a seperate wire for the headlights and the dash lights.
SOURCE: dodge ram 1500 the radio and dash lights are not working
did u look at the fuses under the hood there might be one there other than that sounds like you wiring went bad or the part of your switch is bad replace the switch
SOURCE: 98 jeep wrangler headlights wont turn on
I would check your headlight relay switch that is located in your steering colum
After getting help from a seller on Ebay we found that the dimmer switch was the problem, had to go between ground ( black ) and bulb side ( red/green ) wires.
All bulbs work by testing off board. Had help from EBAY seller who told me it was missing the ground on board, so shorted dimmer wires ground to board wire (black to red/green) and it worked.
