Question about Measuring Tools & Sensors
Display station not showing outside temperature
Posted by Doris Skelton on
ecurbwl
    New Friend:
  • 7 Answers
Check battery status indicator on main weather station of remote unit. If no indication, replace battery in remote unit. If battery is good then check "channel setting" of remote unit to make sure the channel setting on remote unit matches the "channel" setting on main unit. many weather stations will take up to 3 or 4 remote units and they must use different channels to relay the remote imfo to the main weather station unit.
Posted on Jun 25, 2015
The outside temp won't show up on my new weather station
  • Remove all batteries
  • Install batteries in outside unit and wait for it to begin sending temperature signal to inside unit.
  • Install batteries in inside unit. You should see outside temperature displayed.
  • If this doesn't work, the outside unit may be defective.
Apr 04, 2018 | Measuring Tools & Sensors
New la crosse technology wind speed weather station model # CA87092 set up.wind speed and outdoor temperature showed until this morning.new batteries used yesterday in setup. what is the problem?
The instructions for your station call for a specific set up procedure. Batteries should be installed in the transmitter first with time allowed for it to initialize and begin sending data. After installing batteries in the receiver, you should see wind speed and temperature displayed. BUT, here in the real world I have a Lacrosse receiver currently displaying a balmy 67 degrees inside and a not-so-balmy - - outside. I believe the alkaline batteries used in the transmitter lose efficiency or freeze at low temperatures. Warmer weather restores the outside temperature display.
Jan 05, 2017 | La Crosse Measuring Tools & Sensors
Why is indoor display not showing outside temperatures?
If the condition comes and goes, the outside unit may be exposed to extreme temperatures or the batteries may be too weak. If the condition occurred after battery replacement, remove all batteries then reinstall the outside battery and wait for it to "initialize" and begin sending data. ReInstall the inside battery and you should see the outside temperature displayed.
Feb 13, 2016 | Measuring Tools & Sensors
Model 00822A2. Why doesn't inside unit show outside temperature?
If you tried removing and replacing batteries, you should bear in mind that all batteries should be removed to "reset" the station then batteries should be installed in the outside sender first and time allowed for it to begin transmitting temperature. Next, batteries should be installed in the receiver and you should begin to read outside temperature.
Nov 24, 2015 | Acu-Rite Measuring Tools & Sensors
Outdoor temperature on indoor station showing - -.
Check the battery in the outdoor unit, resync them per the instructions, if that does not work check for interference.
Jun 23, 2015 | Equity Time USA 31215 Wireless Outdoor...
How do I get it to display outside temperature?
Usually, batteries have to be installed in the remote unit first, followed by house unit. Allow time for the remote unit to begin sending data to the house unit, then you should see it displayed.
May 15, 2015 | Measuring Tools & Sensors
I cannot get the outside temperature to show on the inside monitor
Try the usual fix by removing batteries and reinstalling/replacing batteries starting with the outside unit. Wait for as long as 10 minutes for the ouside temperature to be displayed on the indoor unit. If nothing happens after 10 minutes, the outside unit may have failed.
Oct 20, 2013 | Oregon Scientific Bar806hga Helios Solar...
Why is the outside temperature not displaying on the base?
After a battery replacement, the outside and inside units have to "talk" to each other before you can get a display. Also, the outside unit's batteries have to be replaced first. You should not press any buttons for 10 minutes until the two units have finished "talking"
Jan 24, 2013 | AcuRite Acu-Rite 00593W Wireless Weather...
My new storm tracker STX7500 weathertech does not display the outside temperature
Take out the batteries in the main station for at least 5 min. Also, check the batteries on your outside station and make sure that they are new and the same brand, not rechargeables. Make sure that the outside station is reading a temperature and humidity first. Make sure that the outside gauge is close enough to your inside station. Having your inside station to near electrical or metal things or the outside station too far from the inside station is the most likely of your problems. To test this, once you've restarted your inside station, bring it close to the outside station and see if it's reading. Also, check the bottom right to see if your inside station has an antenna icon. If so, it's just updating from the radio station that updates your station often. Wait for that antenna to disappear from the bottom screen before trying to figure if your outside station is reading correctly. Finally, make sure that you have the right time zone, state, and city programmed into your inside station. If none of these work, call or e-mail the link in your book. Hope this works.
Dec 28, 2009 | Discovery Channel Toys
Measuring Tools & Sensors Logo
871 people viewed this question
Top Measuring Tools & Sensors Experts
Marvin
Marvin
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
