Question about Canon "Mp49D - 14-Digit 2-Color Printing Calculator - 14 CharacterS - Fluorescent - Power Adapter, Ac Supply Powered - 3.25"""" X 8.88"""" X 13"""" - Silver"
E appeares on screen. Cannot use the ON print mode. Am only able to use calculations on screen. What do I do to clear it. I've tried the clear button & the reset mode button.
Posted by Freda Givon on
David Payne
    Top Expert:
  • Canon Master
  • 14,162 Answers
Posted on Jun 19, 2015
E appear on screen, number keys not working.what should I do.
Customer Reviews: Canon MP11DX Printing Calculator
www.amazon.com/Canon...Calculator/.../B0006HWF...
Amazon.com, Inc.The keys (i.e., numbers) get stuck almost every time I use it. I have to actually wiggle the numbers so I can enter the next number. It's not the tape on the ribbon; ...
3 Using your calculator for fractions - The Open University
www.open.edu/...calculator/content-section...
United States Open UniversityMay 3, 2012 - Early Years · Working with Young People .... 11 Natural logarithms and powers of e on your calculator ... The figure shows the display on a calculator screen.... If your calculator is not in Math mode, repeat the steps of Activity 1. ... arrow keysto move between the boxes when inputting the mixed number.
[PDF]Canon MP270 series / MP250 series On-screen Manual
I will be adding up multiple things, it is printing great, and then the screen goes blank except for a small "e" appears in the lower left hand corner and I have to start all over. WHY?
our calculator is beyond repair. You can use it in no print mode ohly. The printer is not working, causing the error code.
Turn it off and back on and only use the display mode.
1helpful
I have a casio calculator fx-350ES. My problem is that everything that appears on the screen is very bright, I can hardly see anything. Changing one battery did not help.
Press SHIFT 9 To clear and reset defaults.
Or Press SHIFT MODE to enter (Setup). Look for option <CONT>. That changes the screen CONTRAST.
How do I print the total amount on my ticker tape of what I've added? I pressed the equals sign but that didn't work.
OFF • P P•IC
ON POWER SWITCH; PRINT / ITEM COUNT MODE SELECTOR:
"OFF": Power OFF
"•": Power ON. Set to the non print mode.
"P": Power ON. Set to the print mode.
"P•IC": Power ON. Set to the print and item count mode.
1) For addition or subtraction, each time is pressed, 1 is added to the item
counter, and each time is pressed, 1 is subtracted.
• The count is printed when the calculated result is obtained.
• Pressing of , clears the counter.
2) When the grand total/rate setting mode selector is in the ON position (GT), the
counter will count the number of times that the calculation results have been
stored in the grand total memory. To print and clear the count, press the key.
3) The memory item counter will count the number of times that the key has
been pressed in the addition.
Note: • Each time the key is used in the subtraction, 1 will be subtracted from
the count.
• The count is printed when the memory is recalled.
• Pressing of the key clears the counter.
Note: The counter has a maximum capacity of 3 digits (up to ±999). If the count exceeds
the maximum, the counter will recount from zero.
4helpful
Casio fr-2650 plus is showing an E on the screen and not allowing me to input data. Ideas?
Follow theses steps (from Casio Support) :
First, check the batteries, and ensure there is not a paper jam in the printer.
If both are fine, then while the calculator is in the "Print" mode, press the [CA] (or [AC]) button 20 times consecutively to clear out memory buffers. Try some numerical calculations, and if the problem persists, repeat pressing the [CA] button 20 times.
If the problem still persists, then the calculator may require service
1helpful
DEG is on the screen. How do I clear it?
The calculator has three angular modes: Degrees, Radians, and Grads. You're going to be in one of those modes at all times, and the calculator will light the appropriate indicator.
You can press the DRG key to cycle through the three modes, but one of those indicators will appear on the screen at all times.
On the screen appears E and P. And cannot clear and will not print.
Take out batteries and leave out for few minutes. reload and try again. Also try a fresh pair. If it's powered by outlet unplug for same time frame.
CALCULATOR MIS-FUNCTION .
unfortunately the printer is out of time or the selector pawls got bent. would be cheaper to buy a new one than fix this.
1helpful
Vertical bars
What misses these calculators up a lot is stuff downloaded off the internet. Ti 84 even the APPS seem to miss up. It seems like your calculator is trying to execute a bad APP shell or program. Try to free it up or delete any foreign programming if you have any on the calculator.
Canon "Mp49D - 14-Digit 2-Color Printing Calculator - 14 CharacterS - Fluorescent - Power Adapter, Ac Supply Powered - 3.25"""" X 8.88"""" X 13"""" - Silver" Logo
old marine
old marine
Ekse
