Question about Konica Minolta BizHub C650 Copier
Why is a red light blinking at start?
I have minolta c650,when turn on my machine,the start buttom blinkin red light and not copy and print and scan
Posted by mahdibaiati on
Norman J Weimar Jr
  • Konica Minolta Master
  • 6,960 Answers
Posted on Apr 29, 2016
3 Related Answers
Anonymous
  • 167 Answers
SOURCE: Print Booklets with Konica Minolta Biz Hub C650 Printer
Select Print, and then "Properties"
Layout Tab - select Print Type: Booklet
Basic Tab - Select original size and then size of PAPER to be printed. 11x17 is standard 8.5x11 book when folded.
Finish Tab - select saddle stitch.
Thats it, easy as pie.
Posted on Feb 17, 2009
firecontrol7
Norman J Weimar Jr
  • 6960 Answers
SOURCE: Error Code C6103 on Konica MInolta BizHub 451C
Check your scanner home position sensor.Ser manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on May 09, 2009
Alex
SOURCE: Bizhub C650 (Minolta printer, copier)
I usually go into service mode change the setting from table 2 to table 1 that solves the problem
Posted on Oct 22, 2012
Konica minolta bizhub c203 blue data light blink copier not working
Have you cleared all the print jobs currently in the que and on the control panel. also disconnect your network cable power off the machine then on will it copy not print? data light blinking mean job is trying to run is the paper draw or by pass tray have paper an in the correct orientation landscape or portriat
Jan 24, 2016 | Konica Minolta Office Equipment & Supplies
Konica minota c650 Printing balck baground copies
replace the black image unit. and ensure modification lock is installed to ensure proper connection if you pull out the black image unit is there black developer piled up in the rear???????
Jun 20, 2015 | Konica Minolta BizHub C650 Copier
Konica Minolta Bizhub C353 Has not lights on the network card
make sure the new outlet has power coming out of it, It may be connected to a switch or the breaker may be turned off.
Oct 29, 2014 | Konica Minolta Bizhub C353 Color Copier...
Scan bizhub 751
have a tech come out service mode and clear memory
Apr 16, 2014 | Konica Minolta Office Equipment & Supplies
Bizhub copy machine start button blinking
power off the machine using main power switch not the control panel switch
Feb 06, 2014 | Konica Minolta Bizhub 362 Copier
Jan 22, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Is the Minolta cs pro 5000 strickly a copy machine or is it a printer too?
Im pretty sure this is an analog machine. One way to test this for sure is to make multiple copies of one original. If the light scans the paper each time, then it is a analog machine and can't be hooked up to a computer. Digital machines generally scan the document only once then print many.
Dec 04, 2008 | Minolta EP4000/5000 CS/PRO Copier
setup for adf if is new machine u have the setup **** for adf
the setup **** (A4 page) with black border
Oct 13, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
HP psc 750 printer
my computer said that it did not have it on the computer I've used the CD .
May 21, 2008 | HP PSC 750 All-In-One InkJet Printer
Konica Minolta BizHub C650 Copier Logo
154 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
