Question about magicJack Plus
My magic jack is not working it is saying no line
Posted by carol biggart on
Harry Husted
    New Friend:
  • 37 Answers
The Magic Jack needs power. If it is plugged into your computer or the wall jack, but your unit still doesn't have power, the jack could be defective. Why not unplug the jack from where it is plugged in now, wait for five minutes, and plug it back in. If the device still doesn't work, there is a possibility the jack no longer works.
Posted on Jun 19, 2015
My magic jack phone stopped ringing and the handset says no line
It sounds like the magic jack is not getting power. Is it plugged into the computer, or a wall outlet? Is the blue light on?
If it is plugged into a computer then unplug the Magic Jack and reboot the computer wait until it reloads and then plug the Magic Jack into a different USB port.
If it is plugged into the wall, Then unplug it for 5 min and then plug it back in.
If it doesn't come up and it is still covered by Magic Jack open up a chat with them at the link here. http://www.magicjack.com/contact.html
Sep 17, 2017 | Lands Phones
Why does a CS6124 not work with Magic Jack?
that phone should work with magicjack , you are not getting a dial tone because you are no setting it up right somewhere along the line ,
Dec 10, 2014 | VTech Communications Cs6124 Cordless Phone...
I moved. magic jack says no line when hooked back up
  • Is everything turned on?
  • Is the blue light, inside your Magic Jack dongle, on? (Note that the Magic Jack Plus should have a flashing red and green led as well.) If you use the older model you might need to connect it through a powered hub to ensure the device receives enough power to operate properly?
  • If this is a new installation, is your internet service and computer capable of handling the requirements placed upon them by Magic Jack?
  • Do all your connecting cables appear to be firmly attached?
  • Are you watching Netflix, downloading or streaming files at the same time you are attempting to place a call?
  • If you are using the Magic Jack Plus, does the system report Error 3002?
Next, you should ask yourself what recent changes you have made to the computer/Magic Jack software? What recent upgrades have you performed to your hardware? Could this have effected the performance of your Magic Jack?
If your difficulties persist, it is time to divide and conquer. Google a 'you tube' link and watch the video. If you cannot connect to the internet, consult your internet provider for assistance. If the video is choppy, the internet connection might be too slow or bogged down. Perhaps your computer is too slow or requires maintenance. If you cannot hear sound, you might be experiencing problems with your soundcard or sound drivers. You should check Control Panel/Sound and ensure that 'USB internet phone by Tigerjet' is installed.
If the video ran correctly, the next step would be to test your handset and phone cord at another location.
If you prove the handset/phone cord to be correct, you have pinpointed your fault to either the Magic Jack or its software. Contact online support for Magic Jack.
Oct 11, 2014 | magicJack Plus Pc To Phone Adapter
Magicjack phone
Have you tried a new telephone cables going to the magic jack? That would be the first place that I would start.
Can you hook up a telephone to the existing line that's plugged into the magic jack then see if the noise occurs. If yes, then replace the cable. If no, replace the magic jack module.
Jan 22, 2014 | Computers & Internet
Magic Jack quit transmitting, but receives on Brother 775 fax
wheneva i start ma magic jack it say connect to internet an put password its says correct but thn again its comes again connect to internert.... an password an email id... but pls help me in tis..??
Jan 07, 2010 | Lands Phones
Machine not sending information.
Yes, most definately so. There are ways to boost the output signal of your machine but these days nobody has had to do it because lines are much clearer in the western hemisphere. The Magic Jack is great for voice calling but the faxes need instant responses from each other to progress through the initial training protocol and onto the document transmission. You may, if you have one, try another magic jack. It could be down to your particular Magic Jack. Try faxing without the Magic Jack.
Jul 08, 2009 | Brother IntelliFax-2920 Plain Paper Fax,...
magicJack Plus Logo
854 people viewed this question
Top magicJack Office Equipment & Supplies Experts
ray gallant
C. David Graves
Are you a magicJack Office Equipment and Supply Expert? Answer questions, earn points and help others
