Question about Exercise & Fitness
How do I adjust the stride length down?
I inadvertently increases the stride length.
Posted by Cynthia Compton on
Huseyin Huseyin
  • 3,469 Answers
To resett, rekove the battery but you will have to read the instructions to set up again, as stated above. Unlesss you can work out the functins yourself.
GPPD ;ICL
Posted on Jun 18, 2015
How many steps in a mile?
That depends on your leg length/length of stride but as a rule of thumb a stride is reckoned to be approximately a yard as a rough average but people don't tend to stride out unless walking purposefully along an empty road but if they do you can reckon between 1700 and 1800 to the mile. For more normal walking/sauntering steps are shorter and there could be as many as 2500 to the mile...
Jun 12, 2017 | Cars & Trucks
I walk a lot so have bought a Tanita pedometer PD-724.Cannot seem to set stride length Help, Iam 78
That's okay Dorothy ...
I won't hold your youth & in-experience against you.
(Walk a lot: Good girl!)
Tried (really) looking it up... (below) 3 axes pedometer
http://www.tanita.com/es/pd724gl/
Seems 2 B a serious brain teaser. .. but if you have the numbers... weight and stride length.. you just advance to those settings with your mode control.
The only ISSUE I can imagine: you could have your stride length... in CENTIMETERS (METRIC)... So if your stride is
30 inches... that equals 76.2 CM (centimeters).
Aaaand...
if you underestimate your stride a little... It will make you feel like you accomplished more... (and who's to tell).
You go girl...
Comment me back if that didn't do it for you.
If you need to Phone them (Tanita) ...
Tanita Corporation of America, Inc.
Customer Service / Service Center
2625 South Clearbrook Drive
Arlington Heights, Illinois 60005, USA
Phone: (847) 640-9241
Fax: (847) 640-7978
eMail: [email protected]
http://www.tanita.com/en/contact-customer-service/ Contact Customer Service
Personal Scales Manual Downloads
Jan 24, 2016 | Tanita Exercise & Fitness
Can I adjust the stride length?
Precor EFX 546 Version 1 Elliptical Trainer (Refurbished)
www.amazon.com > ... > Elliptical Trainers
Amazon.com, Inc.
Rating: 4.3 - ‎9 reviews
Working out on an elliptical can burn as many calories as working out on a treadmill. ...allowing you to go forward and backward, as well as adjust stride length to target ...The Precor EFX 546 allows you to stride smoothly while holding the ...
EFX® 546i Elliptical Fitness Crosstrainer™ ' Precor
www.precor.com/en-us/.../efx-546i-elliptical-fitness-crosstrainer-33
With the unique Precor CrossRamp® technology, users can alter the path of the EFX®546i between 13 and 40 degrees in both forward and reverse stride motions, cross ...Excellent stability and freedom of movement for users of all sizes.
FAQ - Precor
Dec 28, 2015 | Precor 546 Elliptical
How does a person convert the steps to miles? How many in a mile?
Thats pretty hard to do since each persons stride is different. If you know your stride length then you can just multiply the length of your stride by the number of strides. S x N.
Oct 18, 2013 | Exercise & Fitness
Can you adjust the stride length on an elliptical training machine?
Some machines are sold with the capabilities to adjust stride length; which is a great feature if the machine will be used by more than one person.
Aug 02, 2012 | Exercise & Fitness
Can't input stride length
My husband figured it out! Follow the instructions for setting time and _user information_, toggle the "set" button until you get to stride length (I think it's factory default setting is 33 inches). All the parameters listed at the end of this section are set this way.
May 20, 2012 | New Balance Balance Via Active Pedometer
I want to convert the distance/speed from miles & mph to km & kph to assess the distance and speed after running?
Manual is here: http://www.sportline.com/manuals/370.pdf
SETTING USER DATA The Sportline TraQ is equipped with an advanced Pedometer that measures Steps, Speed, Distance, Calorie Expenditure and Exercise Time. In order to ensure exercise data is as accurate as possible, you must enter your personal profile. 1. Scroll to User Data (display will read AGE) by PRESSING the MODE key. 2. PRESS the RESET key to enter the programming sequence. 3. Adjust Age by PRESSING the INFO key. PRESS the MODE key to Advance to Set Weight. 4. Select Weight Units (LB or KG) by PRESSING the INFO key. PRESS the MODE key to Advance to Set Stride Length. 5. Select Units of measure (INCH or CM) by PRESSING the INFO key. PRESS the MODE key to Advance to Set Stride Length. 6. Select Stride Length Units (INCH or CM) by PRESSING the INFO key. PRESS the MODE key to Advance to Set Stride Length. 7. Adjust WALK Stride length by PRESSING the INFO key. PRESS the MODE key to Advance to Set RUN Stride Length. 8. Adjust Run Stride length by PRESSING the INFO key. PRESS the MODE key to Advance to Set daily step GOAL. 9. Adjust daily step GOAL PRESSING the INFO key and advancing to next digit by PRESSING the MODE key
Jan 02, 2011 | Sportline 370 Traq Motion Sensor Pedometer...
I lost my directions and don't know how to change my stride to a lower number.
Manual is here: http://www.sportline.com/manuals/340.pdf
INPUT YOUR STRIDE LENGTH (Range: 12 inches to 60 inches or 30cm to 150cm) 1. Walk 10 steps. 2. Measure the distance that you've walked either from heel-to-heel or toe-to-toe. 3. Divide by the distance covered to arrive at your Stride Length. 4. Example: measured distance 360 inches, number of steps taken was 10 = 36 inches stride length. Important: Please remember that the length of your stride while walking is different than the length of your stride while running. If you plan to use this pedometer for both types of exercise, you will have to reprogram your stride length when you go from one to the other. 5. Press MODE button to reach the DISTANCE MODE showing MILE or KM. 6. In DISTANCE MODE, press the SET button. The display will show previous stride input in Inches or CM and start to flash. You will now have five seconds to start changing your stride length. If you do not adjust your stride length during these 5 seconds, you will have to start step 3 over again. 7. To change your stride length while the display is flashing, press the RESET button. Each press of the RESET button will increase the input by either 1 inch or 2 cm depending on which mode you are in. If you hold the RESET button, the numbers will increase continuously. Release when the display shows the Stride Length for you. 8. Once you have entered your stride length properly, wait 5 seconds - the display will flash and reset the memory - and the display will return to DISTANCE MODE
Dec 31, 2010 | Sportline 340 Step and Distance Pedometer...
How do i set the stride for the sportline 2007 model 4202
5. Press MODE button to reach the MILE MODE.
6. In MILE MODE, press the SET button. The display will show previous stride input in Inches or CM and start to flash. You will now have five seconds to start changing your stride length. If you do not adjust your stride length during these
8. Once you have entered your stride length properly, wait 5 seconds - the display will flash and reset the memory - and the display will return to MILE MODE.
Sep 20, 2010 | Accufitness SportLine Electronic Pedometer...
Adjust stride length
I went online and used the Omron manual again. I had tried it before and it didn't seem to work but just persevered and had success.
Apr 06, 2010 | Omron Hj 720ITC Advanced Pocket Pedometer
Exercise & Fitness Logo
443 people viewed this question
Top Exercise & Fitness Experts
Tom Chichester
ray gallant
Marvin
Marvin
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
