I could only find specifications for a Kodak EasyShare z700 camera. If yours is actually a z7000, this may not be accurate. The camera hs an SD card slot. It uses full-sized SD cards, but it will not generally accept SDHC cards. My experience has been that any full size SD card of up to 2GB will work. Also, if you have miniSD or microSD cards, you can put them into an adapter to fit the slot, but they still need to be 2GB in capacity or smaller.
SD cards go up to 2GB in size. SDHC cards go from 4GB to 32GB.
The PV-GS35 works with SD cards, not with SDHC cards. Your 1GB and 2GB cards are SD cards. Your new 16GB card is an SDHC card. While SDHC cards fit into the slot, they are electronically incompatible and will not work in devices not designed for them.
The A820 works with SD cards, which are limited to 2GB in size. Your 8GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. You need to use SD cards, 2GB and smaller.
No, if the instructions say that it will only take a SD or SDHC card then that is what you must use. They are different shapes, with different contact layouts, and different formats. They are not compatible with each other unless the devices specifically supports it.
Here is what a typical SD card looks like:
Compared to the xD card:
They generally will not fit in each other's slots.
The 2GB one will be ok. When your manual was written, there probably weren't any 2GB cards around, so they only mentioned the 1GB.
However, 4GB or larger "SD" cards won't work. A card that size is actually an SDHC card. SD and SDHC cards fit the same slots, but they are slightly different. Many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
The A520 uses SD cards. SD cards max out at 2GB in size. A microSD card in an adapter looks exactly like a SD card to the camera, and microSD cards also max out at 2GB. Anything larger is a SDHC or microSDHC card. While they will fit into the slot, they are electronically incompatible and will not work. So, the short answer is: 2GB.
According to the manual, the Z612 uses MMC and SD cards.
Be careful not to try SDHC cards. They look similar to SD cards and will fit into the slot but are electronically incompatible. SD cards max out at 2GB in size.
The C330 uses SD and MMC cards. SD cards are limited to 2GB in size, so that's the upper limit. Cards bigger than 2GB are technically SDHC cards. They will fit into the slot but will not work.
