These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
These blinks are fault indications. Count the number of blinks occurs at one time switch on, and check this link for details. The link contains the blinking codes to many brand TVs.
This problem very common in sharp tv.The POWER,OPC flashes.First turn on have power LED indicator light stable at all? Tries the power again couple times will have backlight come back on,than it will work.Not at all more than 5-6 times than ur main turner signal board is the problem,must replaced.
Don't feel bad. You didn't do anything wrong.
They sent you a TV with a bad power supply board for the
screen. The TV is trying to power up the screen, but it can't. Because of a defective part somewhere on the power inverter board for the screen. That is why the power/opc light is flashing.
I would call them back and and make them replace the TV.
Power indicator blinking is an indication that the protection circuit inside the unit has been activated to prevent further damage. You may need to have the unit checked by qualified technician. Most probable cause is a damage component in the power supply circuit or those directly connected to it (mostly output component).
