Question about Kodak ESP 2170 USB 2.0/Ethernet/Wireless-N Color Inkjet Scanner Copier Fax Photo Printer w/Card Reader & 1.5" LCD
What is the corrective action for error code 3523?
I getting this error code after clearing 3528 error code.
Posted by Marie Foehl on
  • Marie Foehl
    Marie Foehl Jun 19, 2015
    Wanted to update it may help someone som
  • Marie Foehl
    It may help someone someday. I called Kodak tach support after doing the trouble shooting on their site. It led me to error Jo1 something like that it means printerhead jam. They informed me it was hardware failure. I personally think it was a sensor that was bad. All the negative reviews and comments I read I have to say this my Kodak 2170 lasted me 8 years of great reliable service. If I could I would get another. Most paper jams occur when the incorrect grade paper is used. Then the user gives bad review because they do read the manual or do trouble shooting correctly (in the orderon kodaks site) I'm going to miss that printer.
1 Related Answer
Rick Saulnier
SOURCE: cannot clear error code 3523
Had the same problem error 3523 that would not clear. Tried Kodak support with no results so took matters into my own hands.
Noticed the top tray seemed jammed into the printer. Tried pulling it out but it seemed locked. Flipped the printer over, removed 8 screws, 4 metal plates.
Removed bottom tray, set aside. Remove 3 screws for plastic bracket that holds top tray. Move bracket over, be careful not to damage wires. Remove top tray and reinstall so that it is in extended position. There is two notched in the side of the top tray. Extend so that catch is in back notch.
Reassemble everything in reverse order. Take care that the top tray does not slide into the printer when you turn the printer over. It did for me the first time that the tray jammed again.
Replug everything and startup the printer with top tray extended past bottom tray. The printer will tell you that top tray is jammed, push top tray flush with bottom tray.
Printer now works. Don't know why tray jams in the first place but this solution can keep you from scrapping printer or paying for service.
Very disappointed with Kodak printer. Obviously printers were not their core business and they paid a sub-contractor to build these products for them. My next printer will be an HP.
Posted on Jul 21, 2012
Cleared check engine light. How do I pass smog check?
Clearing the Check Engine light does not repair anything - it only turns off the light and clears the error codes. The problem(s) that caused the light to occur are still going to be present and the light will probably come back on, anytime from a few minutes to a few days depending on the problem(s). What you NEED to do is to extract the error codes that come with the light and take the corrective action(s) to repair the deficiencies. That will probably make the vehicle able to pass smog checks. Of course, now that you've cleared the Check Engine light, you've also erased the error codes, so you will need to wait for it to return to get the data you need for repairs.
Dec 30, 2015 | 2004 Dodge Dakota
What corrective action for an le code?
The le error code means the leakage sensor located in the middle of the base has detected water. Check asap to see if there is water leakage underneath the unit. The sensor must be dry in order for the error to be cleared. Usually, when these sensors are active, they will tell the main board which will not allow anything to run until the code is clear--for obvious reasons.
Aug 11, 2015 | Samsung Dishwashers
3523 kodak
There may be a dirty sensor in the paper path...but most likely there is a tiny piece of paper still jammed somewhere that is difficult to see or access.
Aug 01, 2014 | Kodak ESP 7250 All-in-One InkJet Printer
Kodak 3.2 ESP has an error clear all paper code 3528 but there is nothing there
Turn off the printer and unplug it. Open the top access panel. Inside on the left you will see three round, white gears. Rotate the gear closest to the front back and forth with your finger. If any scraps of paper appear near the rollers, remove them. Close the top access panel. Plug in and start the printer. This worked for a Kodak ESP 3.2.
Feb 04, 2013 | Kodak ESP 3 Multifunction Printer/ Copier/...
Stairmaster quinton 612 plus error code e201
Quinton Error E201 Probable Cause Grade Over Limit Fault. Turn jackscrew counter clockwise to get within range.
Corrective Action
  1. Use Up or Down arrows to bring grade into range.
  2. If error persists, replace grade actuator or VSD. NOTE: Belt and display may continue to be used during fault conditions by pressing clear.
Quinton Treadmill Error Codes E201
Mar 16, 2012 | Startrac Fitness Products Exercise &...
Corrective Action
Mar 16, 2012 | Exercise & Fitness
Cannot clear error code 3523 for Kodak ESP 9200 Series all in one printer. Have followed all instructions per Kodak online
Jul 24, 2011 | Kodak ESP5250 All-In-One InkJet Printer
My kodak esp5210 printer is showing paper jam remove rear access cover. clear all papper. attach cover. press ok to continue. (code 3533). ive followed the instructions but nothing changes. there never...
I've got exactly the same situation/circumstances and error code, the thing different is that my code changes between 3533 and 3528? sorry I;m no help right now but I'll be back if I solve it. Martin. ([email protected])
Feb 11, 2011 | Office Equipment & Supplies
Kodak ESP 2170 USB 2.0/Ethernet/Wireless-N Color Inkjet Scanner Copier Fax Photo Printer w/Card Reader & 1.5" LCD Logo
43 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
