Question about Garden
A sthil fs45 trimmer there is a lot of play where you attach the head. do i need to replace the drive shaft?
Eugene Rounds
  • 1,169 Answers
Yes if it is too much play on that curve shaft.
Posted on Jun 17, 2015
5 Related Answers
Anonymous
  • 163 Answers
SOURCE: Ryobi TP30 straight shaft line trimmer convertible - drive shaft disconnected from motor
check both ends of shaft, they're usually a hex or torx head. sometimes the can strip or even snap off. if you find noticable damage replace the shaft
Posted on Nov 29, 2008
Anonymous
  • 81 Answers
SOURCE: Homelite strin trimmer head wont rotate
The only way to access the bottom of the metal shaft is to break it. This is fused on at the factory. It sounds like your flexshaft has twisted in two. Remove the flex shaft from the engine end and see if it is in one whole piece or is damaged in someway. If it rotates at the top but doesn't rotate at the string head this is probably the problem. However, Homelite no longer offers just the flex shaft for purchase. You would probably have to purchase the shaft and the tube as a unit.
But if you are saying the spool and string is not turning at the bottom it could be that the cup which holds the string has worn and can not longer be turned by the shaft. Replace the cup that holds the string.
Another possibility is that the shaft have moved forward, away from the engine and just need to be jammed back in, and retightened (the handle grip and the boom clamp).
Posted on Jun 17, 2009
dropndeal
DROPNDEAL
  • 2931 Answers
SOURCE: remove the trimmer head from shaft
The entire trimmer assembly (from the gearbox forward) will slide off of the drive shaft cover. On the side of the aluminum gearbox assembly, you will find a single screw. This is the "anti-rotation screw" (do not lose this). Then remove the small (approximately 1" diameter) clamp from the end of the gear box assembly and simply pull the entire cutting assembly off of the shaft.
If you just want to remove the trimmer bump head assembly, then you will need to lock the bump head assembly to prevent rotation while you are working. If you purchased this new, then there should be a small metal rod included with your accessories. This will fit in a small hole in the base of the gear box assembly 791-182193 and prevents the trimmer head from rotating.
Then proceed to remove the following items:
791-180814B (replaces 791-180814) Bump Head Knob Assembly
791-147495 Inner Reel (hold the trimmer string)
791-610636B (replaces 791-610636) Spring
791-612026 Retainer (be careful removing this so you do not inadvertently destroy it). If you intend to reuse the trimmer head. If not, then hack, pry, stab, etc.. until you mangle it enough to remove.
791-683301 Outer Spool & Eyelet Assembly should now slide out leaving only 791-612483
Spool Shaft which I will assume that you want to keep.
I replaced my entire string head assembly a couple of years ago (and subsequently misplaced it and am in fact wanting to purchase one) and replaced it with a grass-gater or similar.
I hope this helps.
Posted on Jul 19, 2009
nova2nv
Bill Linda Rivard
  • 197 Answers
SOURCE: Ref: Stihl FS46 string trimmer. Broken Flex shaft.
Remove orange sheild,remove single screw holding head in shaft then grab head with pliers and twist side to side until complete head is free.You should then be able to grab part of shaft.On power head loosen screws {about one turn each} that hold two white case halves near trigger,I think there are four,then there is a single torx screw on the bottom of lower case half in the middle that must be taken out to allow tube to be removed.Romove flexshaft from top.Check 4 plastic burnt to flexshaft,if there is you must replace tube liner as well,usally around bent part of tube the liner will go bad.
Posted on Nov 28, 2009
Anonymous
  • 41 Answers
SOURCE: Craftsman weed wacker trimmer head won't turn
it could still have the broken peice from the old one inside the seat.take it apart and look inside and inspect the seat where the drive cable enters.
Posted on Apr 14, 2010
Stihl FS45 trimmer head bearing housing
The bearing housing is replacable as an assembly, and then is fitted into the end of the shaft/tube
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Sep 13, 2016 | Stihl Garden
Fs 55 has very bad vibration
proably the bearing in the end of shaft. See if head moves back and forth or unscrew head and see if shaft has a lot of play in it. If bad replace shaft.
Aug 14, 2014 | Stihl Garden
How to change the cutting line in a curved shaft fs45 *******
No, I'm not sure why STIHL even makes curved shaft trimmers at all. I have never worked on ine in 10 years of being a STIHL tech, I just throw them out when they don't work and steer the customer to a straight-shaft. It's their punishment for the mistake of buying the curved shaft in the first place.
May 04, 2012 | Stihl Fs45 Trimmer Drum Sprocket 45 55 46
The head fell off my Stihl fs45 string trimmer and the flexshaft came out. Repair or replace?
unless you were misusing the trimmer it is under warranty... if you are the original owner there is a lifetime warranty on drive shafts and cables
Aug 03, 2010 | Garden
Stihl FS45 will not run at full throttle
replace fuel filter in the tank and will be fine it is gummed up .stock part at any sthil dealer
Aug 22, 2009 | Garden
Stihl fs 45 trouble getting the cutting head to engage
repair shop shortened shaft just a touch to take up slack in drive cable
Aug 02, 2009 | Garden
Stihl FS45 2 cycle string trimmer. Bought in 5/06 Cutting head came off while cutting. Flexible shaft still has squared off end so it doesn't seem to be broken. What holds the cutting head shaft with the...
Dealer says shaft has broken. Stihl had a problem with some FS45's doing this. They are trying to have it repaired under warranty.
Thanks for the response.
Jun 22, 2009 | Garden
The trimmer head will not spin under power
The drive shaft is not set all the way into position. You will have to take the front casing off, as well as the lower part of the shaft, and work it into position that way. You may have to play with it a little bit.
Jim
May 30, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
140 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
