Lightning hit and our Panasonic Viera displayed, No signal. TV won't show networks, but Netflix and internet is still working. I'm not sure what part is messed up. The main board?
Cable company came out and checked. No problem with the cable or DVR. We can watch internet shows no problem. The sound is out too. Using sound bar. Ant option says not used and is grayed out.
Re: lightning hit and our Panasonic Viera displayed, No...
Ckexk that your aerial installation is not damaged, it is possible the cable is damaged. If you try another tvvon it an it does not work there is your fault. It may be that the tuner section has gone but I would definitely try the aerial as the first step to a diagnisis in this case
How do I set up my Panasonic TV? Hit the Menu button on your Panasonic TV remote. Select Network > Network Connection. Select Wireless. Select Wireless Network Settings. Find your Shaw network name in the list of available networks and select it. Enter your network password. Your wireless connection should now be set up.
On these devices, the Netflix App can be accessed via VIERA Connect or the Netflix button on your remote control. If your Panasonic Smart Device does not have the Netflix App, it can be downloaded onto any internet connected external device (smartphone, tablet, gaming console).
What type of device do you have to connect to Netflix? If watching in browser on desktop you need to install Silverlight
Make sure that your TV is connected to your home network. It is best to connect it directly to your router with an Ethernet cable. If your VIERA is from the last few years, its should have built-in Wi-Fi, so you can also make wireless connection between the TV and your home network.
Using the Panasonic TV remote, press MENU and select Network. Try the network test.
Try to sign out and sign back in again. Was having the same issue (I think. Was getting "Cannot play title right now, please try again."). Called Netflix support and this was their solution. It worked great, havent had an issue since.
I use to be able to use my phone as a hot spot and it use to work now it just gives me the code 007 It's displays that thier is a connection but only a home/ local.plz help.
on your computer, go into your vga graphics driver and hit properties, set it for dual and hit apply. close the box. then go to the graphics,options, look for dual. make sure the wire is tightly in your tv and computer. switch your tv to vga. it should be lit. then you should see your desktop on your tv screen.
you wont see the pc screen on the tv if that is what your expecting, if the tv is capable of receiving netflix then it will pick that up seperately from the pc, it will only need a wireless connection to access the broadband, you will also need a valid subscription to the netflix service. The fact you have proved you have a valid wireless connection means its connected. There will be an options button to select the internet content to view on viera cast
quote from panasonic ---
VIERA Cast's assorted online content just keeps getting better - in
addition to the popular contents such as YouTube and Picasa Web Albums,
it now offers Pandora Internet Radio, movies streamed from Netflix*,
exciting sports from FOX Sports, tweeting web communications with
Twitter, and even home video and audio conferencing with Skype. It also
provides USB terminals for a keyboard and Wireless LAN Adaptor. No PC
required. Skype function requires an optional communication camera TY-CC10. Skype service will be available late June 2010. *Netflix unlimited membership required. Service on Viera Cast TV will be available summer 2010. *Keyboard and Wireless LAN Adaptor are not included.
Yes!!! When going out for extended periods of time unplug TV's from a/c outlet AND dissconnect broadcast signal from TV(cable,sat. etc)
Isolation is the only sure protection against LIGHTNING DAMAGE!!!
I advise purchasing protection from your' service provider.
