SOURCE: Nokia Security
Master code & IMEI no. has nothing to do with unlocking the security lock of your phone, you need to have a unlocker/flasher
hardware and software to do it or visit your friendly service shop.
SOURCE: Resetting Security Code
SIM pin code:
This is a pin code that locks the sim card until you enter the correct code. This protects your account, even
if your sim is put into another handset. To reset it, you need the PUK code:
Pin Unlock Code (PUK)
If you miss key (or forget) your SIM pin code, and enter the wrong one 3-5 times in a row, the SIM will lock up, and you’ll need to enter the PUK unlock code to release it. You should ask your Network Service Provider for this code when you need it. Don’t try to guess it, because after a few wrong guesses, the SIM card will be permanently disabled.
Phone Security Code:
This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered. To reset it, you need the Master code code:
Master Reset Code
Sometimes known as the Master Code, this allows you to unlock a handset if you have entered the Security Code wrongly too many times.
Which is the one that you want?
The default security code for Nokia is 12345
SOURCE: Need to reset my security code for Nokia 6070. Please help
IMEI: 353235015522555
Master code: 2564610140
Close all applications on your phone.
With your phone switched ON, remove the battery.
Then remove the SIM card.
Replace the battery without the SIM card and switch your phone on.
Type in the security codes (any code) until the phone request the Master code, (in the phone lock window) when it does, leave your phone still, don’t use it for 15 minutes, then type in the Master code.
This is the code needed to reset the Security code, nothing else, and it’s for your phone only.
If it does not request the Master code, your phone will have to be connected to a computer and an unlock box to restore the Security code.
SOURCE: Reset master code for Nokia N73
If you know the risks, try this ONCE and ONLY ONCE and let us know if it works. You have only 3 to 5 tries and then it will be hard locked. After that you will need a cable thing-a-me-jiggy to unlock it. It will still work on your Network so no big loss.
#pw+314646531133130+7#
Remove sim first,power on the phone.
After the phone boots up, press #
Press * 3 times fast for (p) \
Press * 4 times fast for (w) IMPORTANT
Press * 2 times fast for (+) /
and the rest of the code---
IMPORTANT!!
Verify code before pressing the last #.
Pay attention. You only heve about two seconds.
Note:If nothing happens. Some Phones require that you to insert a non accepted sim. Before you do this, make sure the sim you use does NOT have a security PIN CODE. If it does, reset the security code to default 12345 with the original phone. Insert a non accepted SIM and turn it on. You will see "phone restricted", select the UNDO option,then enter the code in the restriction box and press ENTER.
"Phone restrictions off", it's unlocked.
"Error code" wrong code.STOP tell me.
"Not allowed" or "Can Not Undo Restriction" it's hard locked. Used up all your free tries!!
Pls let me know, if it works for u...
