Question about Razor E300 Scooter
E300 razor scooter would run then stop then run then stop. Is it possible it is the batteries even if they read 12 volts on a meter?
Posted by Don Somsky on
Paul Toroid
    New Friend:
  • 8 Answers
Well how long between runs and stops? Batteries can be bad even with 12+ volts on a meter with no load. Is the on/off regular like the controller cycling, or irregular like a damaged wire? The hall sensor in your throttle could be causing it, if it's loose or not working properly. You can open the throttle with a socket and a screwdriver. Check all wiring, check the batteries under load. If you say more about the frequency and duration of the stops and run periods it would help.
Posted on Jun 16, 2015
5 Related Answers
Anonymous
  • 7 Answers
SOURCE: razor e200 runs slow
you need a new battery they cost about 35$ on razor
Posted on Jun 08, 2009
ROB
  • 858 Answers
SOURCE: e-100 razor scooter battery will not take charge
its dead they need to be recharged every time they have been used
Posted on Jul 18, 2009
Anonymous
SOURCE: How do I test my batteries on my E225S Razor
Since the battery could put out 12v and still be bad your best bet would be to take the battery to Autozone or similar and have them do a load test (its free). This will let you know for sure if one or both of your batteries need to be replaced.
Posted on Apr 02, 2010
Anonymous
SOURCE: razor e300 scooter charger light stays green,
I have this same problem? What do you do? I bought a new charger thinking it was that and the light stays green on it too.
Posted on Sep 09, 2010
bayyagg
Bayyagg
  • 1672 Answers
SOURCE: Razor e300 batteries are bulging. Is that normal?
Bulging battery means u have to replace it, the plates started to oxidize and pushes the everything out!
Posted on Nov 09, 2010
Wont start razor e300
On my eZip 1000 scooter, in front of the battery pack, there is a compartment that houses the controller & assorted connectors & wiring. There is also a plastic housing that contains 2 fuses. Check, inspect & test the fuse(s) with an ohm meter for continuity. If all other components are functioning normally, it's probably the fuse(s) that need replacing. Hope this helps.
Oct 02, 2014 | Razor E300 Scooter
E300 electric scooter battery,
The scooter uses batteries specifically designed for deep discharge applications. If your new batteries are not lasting then they may only be suitable for standby or backup type applications like for your house alarm system or garage door opener when the mains power goes out.
Mar 19, 2014 | Razor E300 Scooter
Do UPG 12 volt 7ah batteries work as good as "RAZOR BRAND" Batteries?My scooter is an e300.Do you know if by chance,the e300 scooter needs razor batteries only?I got generic ones,and they are terrible
No. We get batteries from a local supplier and they work just as well. are by far the most common problem with razors because people dont keep them charged.
Razor e300 Continually needs to be reset continuously need to restart my e300 because stops, only has 2 week old, initially worked perfect, then reset again run until stopped again.
I posted a similar issue about the same scooter. If you do replace the batteries and still experience the same issue, check the wiring for loose wires and possibly replace the fuse.
After replacing the fuse and connecting wires, my scooter doesn't pop the fues with every use anymore.
http://www.fixya.com/support/t7752702-ride_scooter_turns_off
Feb 07, 2014 | Razor E300s Electric Scooter With Seat
I was given a Razor E300 and was told that the only thing wrong with it was it needed a new charger. Well, I got the charger and it states the razor is charged but the razor still doesn't work. Any...
You have to make sure that the batteries are still good.
Take a volt meter and read the levels that the batteries are producing. If the levels are too low, then your batteries may have sat, unused, for too long. SLA (Sealed Lead Acid) batteries will generally lose their charge holding capabilities if you leave them in storage for too long without charging them.
YOu can get replacement batteries at this online Electric Scooter Parts Store:
http://www.partsforscooters.com/s.nl?partner=URBANSCOOTERS
-Jackson
http://urbanscooters.com/
Oct 16, 2010 | Razor E300 Scooter
My sons razor E300 duns only at about 2 mph on a full charge. Its only been use MAYBE 20 hours over last 1.5 years and has never had any problems til now. The brake is not overly tight, the chain is lubed...
Dead battery. You must follow the proper battery maintenance procedures in order to prevent that from happening. Most likely the battery has sat for an extended period of time and has dried out.
Oct 09, 2010 | Razor E300 Scooter
I replaced new battery but still the scooter runs slow
The Razor E300 electric scooters are battery operated scooters and can run at 15 miles per hour. This is enough to produce the best fun for kids while on their free time. It's a quiet worker, and with that speed, you won't get scared of the child going too fast to be prone to accident. Yet, it is still good to take precautions. Let the kid wear a helmet, foremost, because this can protect the head should accidents happen.
Your scooter may need new batteries, or a controller. To check these components functionality you will need a volt meter. Check the current coming out of the batteries, check the current going into the batteries and both should read in the 12.5-14 volt range. If your charger, ore the charger connection is faulty you will need wiring, or a charge port. If your batteries are faulty, you will need batteries. Check your controller with a volt meter, or a test light to see that all connections are secure and the controller is functioning properly. If you need parts or repairs done, you can visit this Electric Scooters Parts Store Online with "Find a Repair Shop" feature.
I hope this helps; remember to rate this answer.
Oct 04, 2010 | Razor E300 Scooter
We have A 300 razor battery scooter but do not have the battery pack or the charger.
Buy a replacement battery pack and charger at razor.com or http://electricscooterparts.com/razore300.html
Jul 10, 2010 | Razor E200/300 Electric Scooter Battery
Razor E300 Scooter Logo
314 people viewed this question
Top Razor Toys Experts
gbob59
Dennis Key
Dennis Key
Marvin
Marvin
Are you a Razor Toy Expert? Answer questions, earn points and help others
