Question about Canon PIXMA MP530 All-In-One InkJet Printer
My printer is not working. Can you fix?
After finishing printing 8-1/2x11 pictures, the printer stopped printing and the yellow alarm light is flashing intermittently with the green copy light.
Posted by Beverly Thomas on
5 Related Answers
Anonymous
SOURCE: stop working
The covers are pretty easy to remove and access print catridges once you know how. Unscrew screws as they become available, 4 on back then two on each side then 4 on top. the balck plastic front bezels pop off as do the grey side panles. Try pulling out and up from the top. This can be a little tricky but I have not had to be too brazen and have not broken any panels. I am pretty sure that clicking sounds indicates broken parts and a trip to the repair shop. Basically the lock to keep the heads covered is not disengaging.
Posted on Feb 11, 2008
Anonymous
  • 88 Answers
SOURCE: alarm light wont stop flashing
How old is your printer? Maybe a part in your printer has reached its service life and has to be replaced. Please indicate error messages if there are any.
Posted on Apr 09, 2008
Anonymous
SOURCE: Error code 6A00, alarm light flashing, no copy, print or fax function working
I tried everything. I unplugged the machine and moved the printer cartridges to the far left and cleaned and pressed down the spring loaded sponge on the right, over and over again. I also moved the springloaded thing (w/white plastic) forward and backward. Another suggestion was to move the print cartridge holder back and forth sideways. None of these things helped. And there was nothing visibly out of place. I was stumped. Then I found a thread that suggested Windex!!! Even though the error seemed to correlate with a paper jam that had occurred, I was ready to try anything. I got paper towels and windex (I didn't have an eye dropper). I sprayed the paper and cleaned where the cartridges normally sit. Nothing. In desperation I sprayed each pad below the cartridge in the middle area and I sprayed the "sponge" thingy to the right. Really soaked it. Cycled the on/off about 3 times and IT WORKS! (Fingers are black but that's a minor issue compared to unhooking and transporting and waiting and paying for service...) When you cycle the Windex through it soaks up the sticky dried up ink and cleans things up. Don't use other cleaners--use Windex or water.
Bonni
Posted on Feb 26, 2009
Anonymous
  • 84 Answers
SOURCE: Flashing lights and no printing
If the two lights are blinking persistently and the carriage is moving freely when the cover is opened then the logic board has problem and should be replaced. However, if there is some restriction of carriage movement or cracking noise, the optical cable should be replaced. Good luck
Posted on Apr 29, 2009
ranma78
  • 71 Answers
SOURCE: canon ip1800 printer not working
when the yellow led flashes is never a good signal... you should check the manual's printer to find out the error code meaning "4 yellow flashes and 1 green)
Usally it's the waste tank that is full, in this case you need to:
  1. Push “resume” for 5 seconds for canon IPXXXX.
  2. Push Power switch then remove power cord.
  3. Insert plug power cord while pressing “power switch” at the same time.
  4. Push Start/reset by step 2 continue Wait display shown “0′
  5. Push + change display from “0′ to “1′
  6. Push color button 2 times
  7. Push Power switch again , Printer will print 1 page
  8. Open cover
  9. Unplug power cord
  10. Take out ink cartridge #40 and #41
  11. Insert plug again
  12. Push power switch
  13. Open cover (scan cover)
  14. Insert ink cartridge #40 and #41 again
Posted on Jul 18, 2009
Printer prints one line, then alarm light comes on and stops printing.
Sir the printer is giving line because the cartiage or toner is not of good quality so it does not melt properly and produces line while the alarm comes and stop printing is due to the problem in charging cathode or gutter
Jun 03, 2013 | OKI MICROLINE 321 Turbo Matrix Printer
Override empty ink tank on Canon PIXMA MX860
The title of this topic is for the MX860. It has no "RESUME" button, so the advice submitted by cene765 does not work. But there is a solution.
The MX860 has two black ink cartridges--one small (like the colored ones) and one large. So, you will run out of colored ink way before you run out of black. I found that by selecting the "Gray scale" printing option, I could still print with color cartridges being very low. Even when the printer told me that the color cartridges were empty, I could still print by clicking the "OK" button. However, this does not last. Eventually, the printer will flag the color cartridges with an alarm. When that happens, the printer stops working, freezing at the alarm until you replace the cartridge.
However, you can still print. What you need to do is press and hold the STOP button for a few moments. The alarm will be released and then you let go of the button. Printing can resume. This happened to me where the alarm was triggered by the cyan cartridge, before I could even try to print. When I used the STOP button bypass, printing started but was then flagged by the magenta cartridge. I thought for sure that pressing STOP while in the middle of starting the print cycle would abort it, but thankfully it did not--the alarm was cleared and printing resumed.
May 24, 2012 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
8110 printer stops printing after running the yellow and red colors...will not feed paper back in to finish with the rest of the printing...not sure what to do
It sounds like you may have a damaged ribbon (transfer film)
Take out the cartridge and with the barcode side facing you, turn the left spool (takeup spool) counterclockwise until you have seen a complete square of cyan (blue) and magenta (red) and yellow (actually yellow) go past, and then reinsert the tri-color cartridge.
Feb 27, 2011 | Kodak Picture Maker Kiosk Printer
Printer not working.
Start the printer in the service mode.
i. With the printer power turned off, while pressing the Stop button, press and hold the ON
button. (DO NOT release the buttons).
ii. When the Power LED lights in green, while holding the ON button, release the Stop button.
(DO NOT release the ON button.)
iii. While holding the ON button, press the Stop button 2 times, and then release both the ON
and Stop buttons. (Each time the Stop button is pressed, the Alarm and Power LEDs light
alternately, Alarm in orange and Power in green, starting with Alarm LED.)
Without the scanner (connect the operation panel unit.);
While holding the ON button, press the Stop button 3 times, and then release both the
ON and Stop buttons. (Each time the Stop button is pressed, the Alarm and Power
LEDs light alternately, Alarm in orange and Power in green.)
iv. When the Power LED lights in green and "Service Mode Idle" is displayed on the LCD, the
printer is ready for the service mode operation.
Start the Service Tool on the connected computer.
i. When a button is clicked in the Service Tool dialog box, that function is performed. During
operation of the selected function, all the Service Tool buttons are dimmed and inactive.
ii When the operation is completed, "A function was finished." is displayed, and another
function can be selected.
iii If a non-supported function is selected, "Error!" is displayed. Click OK in the error message
dialog box to exit the error.
(7) Main Main ink absorber counter
resetting
Set a sheet of A4 or Letter sized plain paper. After
the ink absorber counter is reset, the counter value
is printed automatically.
(8) Platen Platen ink absorber
counter resetting
Jul 06, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
ALARM light flashing, wont let me print.
hold down stop/reset button for 7 sec. If that doesn't work try holding it down for 14 sec.
Dec 10, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Alarm/error and paper jam when not jammed
Power up printer,then press & hold (STOP/RESET)button for 5 sec. Then restart printer.I think it fix your problem.
May 11, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Alarm flashes ink emptyhas ink! color was printing only yellow/green now prints only red/pink!
any chance it has dried out? run the test / head cleaning / did you reset the cartridge when you replaced it? generally if one or two colors work - the problem is the ink cartridge or the head for the colors not working. Did you remove the "tape" on the new cartridge?
Apr 16, 2009 | Office Equipment & Supplies
Canon mp780 -waste ink near full??
Dear mr perfect,
Few days ago I have answered the same question about this for Canon MP700. Here is my answer:
Waste ink absorber capacity of your printer has rise to about 90-95 %. Tentatively, you can continue printing by pressing STOP/RESET button. When ink absorber capacity reach about 100%, the printer stop working and message 'Waste Ink Tank is Full' appears.
To fix this problem, you need to reset waste ink counter. It strongly recommended that you replace waste ink absorber after resetting waste ink counter.
Here are steps resetting waste ink counter of this printer:
  • With the machine power off, while pressing STOP/RESET button, press and hold the ON/OFF button. (Do not release the buttons).
  • While holding ON/OFF button, release the STOP/RESET button. (Do not release the ON/OFF button).
  • While holding the ON/OFF button, press the STOP/RESET 2 times and then release all buttons. (Each time STOP/RESET is pressed, the alarm LED and COPY lights alternately starting with alarm LED).
  • When the COPY button lights in green, press STOP/RESET button 4 times. (Each time STOP/RESET is pressed, the alarm LED and COPY lights alternately starting with alarm LED).
  • Turn off the printer.
Your printer should work normally now.
Regards,
Source:
Canon IJ Forum
Dec 06, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon Pixma MP160 printing problem
Hi I hate to be a pest but can anybody tell me how to fix a scanner error when I turn on the MP180 printer the alarm light comes on and the i get the scanner message regards Ted
Feb 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Alarm
look in the manual for alarm codes, on? flashing?
possibility something wrong with the carriage, this is the black piece where the ribbon sits on, there are gears in there that will break, very common
1) take out ribbon and print, if it continues to print a few lines without alarm, it's a bad ribbon.
2)turn off printer and move the carriage my hand from side to side, should be smooth, if you hit a bump or tick, it's the carriage.
Sep 14, 2007 | Office Equipment & Supplies
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
80 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
