Question about Garden
Why does my pressure washer cut out after a few minuets use ?
The machine is about 3 years old
Posted by harry walker on
k spencer
    Habit-Forming:
    New Friend:
  • 17 Answers
Solenoid points have dirt n them, or have been burnt at some stage, and the spring tension has weakened,
Out with them and replace with new set, if its a popular model, they are not too expensive, if its an odd brand, find the part number, 99.9% of the time, another breed will fit,
Aslo check fine filters ( more than likely nylon ), for dirt or gunk,
If the washer is being used from a deep well bore, heavy minerals
can block filters...if this is the case, make a solution of hydrochloric acid & water, about 50%, even weaker, wear rubber gloves & eye protection, ( this is a must) , keep children at bay and just use common sense, this will 100% remove any mineral deposits and leave the nylon intact,
Also check for spiders, small frogs 'The Mud Wasp', 99% of the time a visual inspection will tell you , Always unplug if its 240V (Australian) ( 110 ? American ) . you will know that,
Also check for leaks,
If the pressure washer is electric or petrol or diesel, the pressure points work on the same principal
Hope this helps
Regards K1PA
Posted on Jun 15, 2015
Motor fires up fine runs slightly rough for about 10 seconds then smooths out for about 5 seconds and cuts off. Will start right back up after about 5 seconds and does the same thing. I have drained the...
Previous owner had way overfilled crankcase oil. Oil had gotten into carb and clogged air filter. Drained oil to correct level. Ran engine but kept cutting off-see above. Took off carb cover cleaned housing and ran without air filter-ran fine. Unsuccessfully tried to clean air filter with gas-did not work. Apparently, the engine could run just long enough to exhaust the air in the old filter and cut off which is why it would start back up after a few seconds. Bought new air filter-whole thing-about $15 at Carquest. Put in some carb cleaner and installed the new filter and it runs perfectly.
Jun 10, 2014 | Homelite Pressure Washer. 2700 psi 2.3 GPM...
Xtreme pressure washer keeps cutting out.
If it is a gas powered machine and it cuts out when you release the spray gun trigger, it means that your unloader valve is stuck closed.
It would help to have more information about your machine and your problem. Gas or electric? Does it start up and run fine or cut out a few seconds after starting? Does it cut out when you release the trigger?
Does it cut out while spraying?
May 07, 2014 | Garden
Drain pump continuously running on Samsung Model WF448AAP/XAA
do pull the plug out first
not funny dancing with the machine
have you checked the pressure pipe for any cuts
look near the pressure switch area first
Feb 05, 2014 | Samsung Washing Machines
I HAVE AN OLD, ABOUT 15 YEARS,PRESSURE WASHER MODEL 270M. RECENTLY IT STARTED TO PULSATE WHEN I ACTIVATED THE WAND CONTROL. IT PULSES AT THE RATE OF ABOUT 1 SECOND INTERVALS. IT WILL NEVER STOP AND RUN. I...
To me this problem sounds like there is something wrong with the pump.
I think its better to buy another Karcher machine and get the 12 month warranty. As with old pressure washers you could spend money on certain parts to fix the machine but a few weeks/months down the line a different part of the machine could break and then you end up having to buy a new machine anyway.
Also being 15 years old you would have to check to see if parts are still made for the machine. This is because once Karcher discontinues a machine parts for that machine are manufactured for 10 years from that discontinue date.
Jan 17, 2011 | Karcher Garden
Honda gas power pressure washer runs for awhile then cuts off.
did you pour all of the old gas out before you started to use it. Sometimes condensation builds up in gas tank when stored. You need to dump old gas an put in new gas.
Jul 27, 2009 | Honda Karcher G4000RH Pressure Washer
Indesit 126 washer/dryer
I have had the same problem. I thought it was the pressure switch as this is what the error code means - low or high pressure resulting in cut out. I too thought id fixed the problem but it has returned
Sep 10, 2007 | Indesit W 123 Front Load Washer
Garden Logo
195 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
