Question about Coby DVD938 Theater System
When turned on no power all I get is dl sc on the player
Posted by PrimeTime23Killa l... on
Wes Cichosz
    New Friend:
  • 28 Answers
It's not reading the disc. Either the disc is incompatible or damaged and unreadable. Laser head could need cleaning. If there's a disc in the machine, remove it.
Posted on Jun 14, 2015
CD player not working
Hello, I may be able to help. When the SC board powers up, it should go through a lengthly sequence of numbers indicating program versions of the SC board and the player itself. It should then stop with a solid "0". At this point, if you have a CD on the player (and clamped with a magnetic puck, from the clamp arm), you should be able to make it play by pressing the middle button on the SC board. The display should flash "8" while it's reading the table of contents, the display 0-1, indicating that it's playing track 1. If this fails, and you know that the player is o.k., I would expect that the SC board needs repaired. I can repair this for you, as well as help with removing it from the machine. Please feel free to email me, [email protected].
Mar 20, 2010 | Wurlitzer Jukebox 1015 One More Time...
The Homedics SC 380 scale does not work after the battery insert
ensure the battery contacts are clean, if they are corroded it wont work. You may have to buy a contact cleaning spray or brush to do it.
Jan 28, 2010 | Health & Beauty
I have Samsung Sc-d173U. I followed the steps to
finalizing the disc depends on the type of disc that you are using
dvd-rw, dvd-r, dvd+r dl are the only types that you can finalize
Jul 02, 2009 | Samsung Video Cameras
No dl sc message when Video is loaded
STILL NO ANSWER, WHERE ARE THE EXPERTS HIDING?
Feb 15, 2009 | Memorex Progressive Scan DVD Player...
DVD will not load
Firs try to clean the lens with CD/DVD cleaning disk (it might be $1-5 depending on store)
Also check if DVD disk not upside down.
Also chek the DVD disk for scratches
Good Luck
Dec 25, 2008 | Daewoo DVG-9200N DVD Player
Finalizing dvd
Sounds like not correctly finalize??
Jul 27, 2008 | Video Cameras
Panasonic SC-HT75 Home Theater system
with the unit switched on press and hold the stop button and press the power button once. if that doesn't work then try it with the play button.
Mar 31, 2008 | Panasonic SC-HT75 System
cds play fine but "no disc" comes up when trying to play dvd movie
Oct 18, 2007 | iLO DVDR05 DVD Recorder
Coby DVD938 Theater System Logo
132 people viewed this question
Top Coby Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
