Question about Kyocera Mita KM-2050 Printer
How to reset all originals in DP Kyocera km 2050
Posted by Brian Serete on
Doug Sneddon
    New Friend:
  • 60 Answers
It just means take all the pages out of the document feeder on top and put the whole complete document in again
Posted on Jun 14, 2015
Asghar Nadeem
    Champion:
    New Friend:
  • 245 Answers
Assalamoalikum dear you take all paper on document
feeder
Posted on Jul 04, 2015
5 Related Answers
Sam
  • 36 Answers
SOURCE: kyocera km 2050
The 2050 uses 2 network connections, one for the printer and one for the scanner.
Before I go into any great detail,
Do you have a home network? Are you using a switch?
Are you printing through the network connection or the USB/parallel port?
Are you trying to twain scan? Do you have the software CD for scanning.
If not, you will need to download the drivers from the Kyocera web site.
Posted on Apr 08, 2008
Anonymous
SOURCE: kyocera km-2050 scanning function
The km 2050 was on network, but moved to home and directly into tower system via usb interface connector. Printer works, but can not get scanner to work? read instructions without a clue. can someone help with correct proceedure?
Posted on Mar 12, 2009
mysticus_tam
Tammie Duggan
  • 57 Answers
SOURCE: Error Code C6050
First you must get into the service mode by keying in 10871087
The screen will start blinking - then key 163 and the screen should read cancel or execute -select execute
when it is complete turn unit off then back on and see if that worked, if not buy a new fuser unit. They cost around $150,00 to $200.00 depending on who you buy it from.
Posted on Dec 21, 2009
MSM
  • 165 Answers
SOURCE: How to reset maintance call on kyocera km-1635?
10871087 then 251 then hash key then set it to 0 or cancel to reset the counter
Posted on Apr 05, 2010
bndebelevet
SOURCE: KM-2050 Printer: i need to find the pin number to my kyocera km-205...
I need to create a new pin on kyocera 5050 machine as the old one is lost
Posted on Aug 16, 2011
Lost the pin code for kyocera 2050
The default code for the Kyocera KM-2050 is 6482.
Jun 30, 2015 | Kyocera Mita KM-2050 Printer
Kyocera km 2050 drum reset
press10871087 after counter reast all
May 12, 2014 | Kyocera Mita KM-2050 Printer
HOW i CAN FIX THE ERRO C6400
press10871087 after press163 reast
May 09, 2014 | Kyocera Mita KM-2050 Printer
May 05, 2010 | Kyocera Mita KM-2050 Printer
Printing problems Kyocera KM 2050
when this error comes up..hit the print button on the left hand side..this will than tell you on the screen wha the actual problem is..i.e ( out of paper...lost connection etc
Jan 29, 2010 | Kyocera Mita KM-2050 Printer
Kyocera km-2050 scanning function
Mar 04, 2009 | Kyocera Mita KM-2050 Printer
Driver
From links below you can download driver and manual:
KM-2050 driver KM-2050 utility KM-2050 datasheet KM-2050 installation manual KM-2050 user manual
KM-2050 documentation
Do not forget to rate the solution.
Thanks
Feb 23, 2009 | Kyocera Mita KM-2050 Printer
Kyocera Mita KM-2050 Printer Logo
2,850 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
AAAA262430
Marvin
Marvin
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
