It was not used for a while. When I started it it was indicating a battery low voltage problem (the Motherboard battery) so I replaced it. Now it will not boot.
Hi Jeremy,
My name is Pradeep and I work for Dell's Social Media Team.
The flashing LED power light means the power supply is receiving power from the source, but is unable to properly distribute it to the components.
Please turn off the system and unplug only the power cable and disconnect external devices. Press and hold the power button for 15 seconds. Plug in the power cable and check the status.
Please remove CMOS battery and wait for 5 minutes to drain the power from motherboard. Please try reseating with spare CMOS battery and check the results. If this doesn't , please contact local technician for further assistance.
Pradeep Lokesh
Social Media and Community Professional
Order Status: http://del.ly/61822hij
Download Drivers: http://del.ly/61832hid
If the power light is flashing yellow, push and hold down the power button until the machine shuts off, then turn it back on.
If that doesn't work, pull all the memory and try each of them by itself. Once you get it to boot, use any bootable memory tester to check test the memory.
