Washing machines don't usually run silently, but in most cases, a squeaking noise that occurs while the washer is agitating the clothing is not normal and signifies a problem. If the noise only happens when the washing is agitating, the problem is likely connected to the motor or your water pressure. Depending on the specific cause, you may feel comfortable fixing it yourself. Otherwise, call a professional.
Other People Are Reading
The Agitator
Motor Problems
Water Pressure Issues
Considerations
Read more :http://www.ehow.com/info_12131280_washer-squeaks-agitating.html My Washer Squeaks When Agitating eHow
SOURCE: Agitator won't spin back and forth like its stripped
I think what you have going here is some worn agitating ears. In the appliance world we call them dog ears. You have to remove the fabric desp, it should just pop off. Under there will be a cap that you can grab with a needle nose pliers and pull the cap off. Now you will be looking at the bolt that holds the agitator to the shaft. Remove this bolt and you can get to the dog ears and plastic bearing. There is a kit for this and the part number is 3951682. This is not a hard fix...just take your time and observe. Catriver...post back.
SOURCE: ** agitation just spins
It may be the agitator directional cogs, aka agitator dogs. If you remove the top "cover" on the agitator, they're inside of there. They are 4 yellow/clear colored rubber pieces with little teeth. If the teeth are gone or worn, that is most likely your problem. Click here to see a picture, and part details.
SOURCE: why wont my washer agitate
must be worn out dogs
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Hoover 7.5 kg Auto Boss system washing machine won't agitate or
It appears your drive belt/coupling has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
