Question about Homedics Shiatsu Massager
Can use homedics shiatsu back massager if I have a pacemaker
Posted by john rimmington on
3 Related Answers
Anonymous
  • 5 Answers
SOURCE: Faulty Homedics SBM 300H Therapist Select Shiatsu.
My mom had the same problem so i unzipped it from the back, and once i started to take out the padding i saw that there was a wire unplugged so i plugged it back in and it worked!
Posted on Dec 30, 2008
Anonymous
  • 35 Answers
SOURCE: how to replace power cord om homedics massager
This is a test by FixYa Staff.
MODS - DO NOT REMOVE
Thank you!
Posted on Sep 22, 2009
Anonymous
  • 3 Answers
SOURCE: Adapter for homedics shiatsu back
Radio Shack, you need to know how much amps it needs and might have to bring it in to fit the plug.
Posted on Dec 16, 2010
Hi yesterday i was using my homedics cushion . I had it set on shiatsu and i was controlling whereit went. I accidently pushed roller full...well it startd to go upwards and then started making clunki
mine did that and I tried turning it on and let it run through the cycles with no pressure on it. then it found its own track again and started working ok, but I am very careful with the controller now. Hope it helps.
Oct 13, 2017 | Homedics Quad Roller Massaging Cushion...
Conair massager model 4502ST
I have a homedics shiatsu massaging cushion model SBM-300. I have lost the power adapter. The box says 120VAC/12VDC 1A. I cannot find a replacement anywhere. Any help would be appreciated. Thanks
May 02, 2012 | Conair Heated Back Massaging System Bm1
Need a power adapter for the homedics sbm300 massager
No longer available from Homedics. Just called them today and found this out.
May 29, 2011 | Homedics SBM 300H Therapist Select Shiatsu...
Massager squeaks
Zip off the cover and add some talcum powder to the inside cover where the roller make contact with the cover.
May 03, 2010 | Homedics SBM 300H Therapist Select Shiatsu...
I have a Shiatsu Massaging Cushion....it will not operate...blue power LED blinks.
This link take you to Homedics web site...to the right of the picture you will see "Support Information" click that tab to download a useer manual....I hope this helps.
http://www.homedics.com/products/massage
Jan 03, 2009 | Homedics Shiatsu Massager
Nov 27, 2008 | Homedics SBM 300H Therapist Select Shiatsu...
Homedics Shiatsu Massager Logo
512 people viewed this question
Top Homedics Health & Beauty Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
