Question about Lenovo ThinkPad R61 Notebook
What kind of memory can be added to Lenovo thinkpad r61?
Hanging up, think it needs memory added
Posted by high_country on
How to reset lenovo thinkpad r61?
Please follow the steps below to reset the lenovo to factory settings
Note: All your data will be lost. So keep that in mind.
So take the backup of your data first in a separate HDD or flash drive.
1. Switch off the Computer
2. Press the power button and then immediately start tapping f11 key on the top of your keyboard.
3. You will hear a beep sound and then stop pressing it.
4. You will get the screen says windows is loading files. Wait untill it finishes.
5. Select the default language which is US and Click on next .
6. Enter your login credentials (username and password) if you use to login to the windows.
7. Then you will get the system Recovery Options screen where you need to select the last option "Lenovo Product Recovery"
8. Again preferred language will be English US and hit Next.
9. Accept the terms and conditions and hit next and then hit Yes on the warning.
10. Then it will start resetting the Lenovo Think pad to the factory default with no previous data. Same as when you purchased it.
If you have any query you can ask before restoring the Computer.
Hope this helps you. Reply if that fixes your issue.
Sukhiii
May 07, 2014 | Lenovo ThinkPad R61 Notebook
Lenovo r61 startup repair is not working
What were you doing before it happened?
Apr 15, 2014 | Lenovo ThinkPad R61 Notebook
I am hearing 4 beeps 4 times during power on, but system does not start- IBM thinkpad lenovo R 61
Usually this means that the memory is defective or has been removed or popped loose in its sockets. Try to reseat the memory DIMMs or replace them.
Sep 24, 2013 | Lenovo ThinkPad R61 Notebook
Remove dent
IBM/Lenovo ThinkPad R61 Notebook PC >
Bottom Case Cover, (Base Enclosure),
http://www.ebay.com/itm/NEW-IBM-45N4073-Lenovo-Thinkpad-R61-15-4-Bottom-Case-Base-Cover-42W2231-/360642073440?pt=US_Laptop_Housings_Touchpads&hash=item53f7f15360
Keyboard/Palm Rest Cover Bezel,
http://www.ebay.com/itm/IBM-ThinkPad-T61-T61P-R61-14-1-upper-keyboard-palmrest-bezel-cover-42W2466-/400491727269?pt=LH_DefaultDomain_0&hash=item5d3f2ac9a5
Palm Rest Cover,
http://www.ebay.com/itm/Palmrest-Assembly-Cover-IBM-Lenovo-ThinkPad-R61-R61i-14-1-Laptop-/281030800308
Not advertising for seller nor website. Just examples.
Here is the free HMM from Lenovo Support.
It is the Hardware Maintenance Manual. The Service Manual.
Shows and details how to replace the above parts,
http://support.lenovo.com/en_US/detail.page?LegacyDocID=MIGR-67760
Also USE an ESD wrist strap, and have it's alligator clip attached to a good ground source.
Here is an average example,
http://www.radioshack.com/product/index.jsp?productId=2103245
For additional questions please post in a Comment.
Or click on Reply at end of solution, and post.
Regards,
joecoolvette
May 19, 2013 | IBM Lenovo ThinkPad R61 Notebook
Ibm r61 hangs when i connect projector
1.It can happen if any antivirus/firewall software blocking access to things . (in which disabling the the software before connecting would fix the issue)
2. Try to update driver for your Touch pad, This could also solve the problem.
Aug 18, 2012 | Lenovo ThinkPad R61 Notebook
Horizontal lines in lenovo r61
This is a indicator of defective LCD screen, the only option is replace the laptop monitor, go to www.ebay.com Type make and model of laptop, refine search to screen to get an idea of pricing.
Jul 03, 2012 | Lenovo ThinkPad R61 PC Notebook
How many ram bank is available in IBM lenovo thinkpad R61i model laptop?
Click here for the ram specs on the R61. Click here for the ones on the R61i. This should have all of the information you need. Please rate =]
Mar 04, 2011 | Dynamic 2GB RAM Memory Upgrade for the IBM...
Getting beep sound when i start my laptop R61, cannot start
Hi. I think the problem on your machine is the RAMS if you here the beeping sound. I would suggest that you remove the memory and clean the contact points with an eraser but make sure that you remove all the receduces and also make sure that when you plug them back you should double check if they are properly seated. If you still having the same issue after doing the troubleshooting step then try a known good memory so that you could make sure that the problem is not with the memories you have.
May 14, 2010 | Lenovo ThinkPad R61 Notebook
Lenovo r61
Please look here:
http://www-307.ibm.com/pc/support/site.wss/MIGR-67856.html#bluetooth
Drivers and software - ThinkPad R61
Communications: Bluetooth
Communications:
Bluetooth
R61
Bluetooth Enhanced Data Rate software
Windows Vista
03 Apr 2008
v6.1.0.4500
Windows XP, 2000 25 Aug 2008
v5.5.0.4300
Microsoft Bluetooth support
Windows XP 21 Sep 2005
v2.00
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-70450http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-70450
Nov 04, 2008 | Lenovo ThinkPad R61 Notebook
Lenovo ThinkPad R61 Notebook Logo
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
