Question about Saitek X52 Flight Control System
X52 will not hold a steadymain gun in tank or guns in airplne. I have calibrated over and over.Still yhe guns drift.
The guns drift. When in a tank and aiming the main gun, it drifts off target. With hand off of mouse or twisty stick, the aim point moves around. I have unplugged all cables and plugged them back and calibrated. The gun still drifts.
Posted by william w millsaps on
1 Related Answer
Daniliuc Andrei
  • 50 Answers
SOURCE: I need the cable from the stick to the throttle on
Yes the cable is a PS/2 cable at both ends.
It's a standard one you can get it anywhere, any electronic store, ebay...
Hope it helps...
Posted on Apr 29, 2011
1helpful
At start it says calibrate, I shoot and it makes sound but nothing appears on tv
set a cellphone camera to on; place it in front of the gun and, "fire" the gun: if you see a small light on the camera viewfinder;
coming out of the gun barrel the infared led in the gun is working; if not replace the gun.
My 20 ga stanley bostich air stapler stopped firing the staple all the way in. Any ideas?
Do you have an adj pressure gauge? Take it off, you don't need it for nail guns, Only for painting. Guns run on a full tank, wide open, 120 lbs pressure. If that doesn't set your nail, either the safety is holding you off your work and not letting the staple seat or the gun needs to be rebuilt. Check the drive pin and make sure it didn't break the tip off. Sometimes I wish mine wouldn't set the nails all the way, because some materials, it goes right through. You have to hold it off manually. Also, depending on material, some guns do not have the power to drive into Oak. Only the Senco has the power to do that. we tried every gun made and found it to be the best. Got rid of all the other guns and kept a complete line of Senco guns in our shop. Hope this helps.
Jun 17, 2010 • Garden
Power shot stalel gun
there should be a silver clip thing thats over the mag that holds the staples try sliding that down and then it should open 4 you
PLZ RATE THIS IF U FIND IT HELPED YOU IN ANY WAY TANKS.
2answers
Light gun support
tv has nothing to do with it,,sounds like you need a new gun for it ,,
Starting and stopping of air compressor ( no leaks)
This can depend on many variables . (1) How big the air tank of the compressor is, (2) how many PSI the compressor is set to hold, and (3) how many PSI your air gun uses per shot. If you gun is rated at a very high PSI and your compressor has a small tank and low PSI, you may want to consider investing in a larger tank.
Setting up the Crisis Zone Game and guns on a PS2
yep plug the guns in to the controller ports or one controler in one port and the gun in the other port go to calibrate to calibrate ur guns and ur off man good luck
Saitek X52 Flight Control System Logo
Top Saitek Video Game Consoles & Games Experts
Ekse
 TE5LA
TE5LA
ADMIN Canada
ADMIN Canada
Are you a Saitek Video Game Console and Game Expert? Answer questions, earn points and help others
