Question about Connex Radio Communications
SOURCE: how do you dim display lights on a connex cx 3400
O the front you should have a dim switch its on of 4 up & down switches ? if not check on the back ? was it bought as a new cb or was it 2nd hand as the dimmer switch may of been used for something else
Posted on Mar 09, 2010
SOURCE: how to convert a connex
That needs to be done by someone that knows how, theres soldering involved. most cb shops will do it for $free-$10.00... Don't pay any more than that.. there are no parts nor is it hard so they shouldn't charge much.
Posted on Mar 01, 2011
SOURCE: Connex 3300 HP won't change channels when you turn
There is a board in the CB called a PCB board. If you open your radio it is a little circuit board. Held onto the side of the radio by a screw and has two or three connectors leading to the board. Replace that little board and your radio will be good as new. I have seen radios come in my shop many times and this is the fix. What that board does is send a signal to the crystals to start mixing a frequency. When it goes out it just sticks where it is at. Here is a link to a place that can take care of you. http://www.hyelectronics.com/default.asp You tell them you need the little PCB board for a Connex 3300 inside the radio. Might be $35 or so.
Posted on Mar 18, 2011
Aug 30, 2018 | Connex Radio Communications
Jan 22, 2016 | Connex CX-3400hp AM/FM 10 Meter Amateur...
Apr 17, 2014 | Connex Multicolored Lights 3400 Hp 3400hp...
Nov 27, 2013 | Connex Multicolored Lights 3400 Hp 3400hp...
Nov 09, 2013 | Connex Multicolored Lights 3400 Hp 3400hp...
Jan 20, 2013 | Connex Multicolored Lights 3400 Hp 3400hp...
May 13, 2012 | Connex CX-3400hp AM/FM 10 Meter Amateur...
Jan 12, 2012 | Connex Radio Communications
Feb 12, 2011 | Connex 3300 240-Channels Base CB Radio
Mar 09, 2010 | Connex 3300 240-Channels Base CB Radio
379 people viewed this question
I would say the battery too.
